Old 7/2/10, 6:51 PM
David Nasser's Avatar
David Nasser David Nasser is offline
Default Sub panel? or Disconnect... need feedback
Looking for info on the sub-panel next to main panel. It was locked.
Need a home inspection in Oregon? Check out InterNACHI's listing of Oregon certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/2/10, 7:03 PM
Jeffrey R. Pope's Avatar
Default Re: Sub panel? or Disconnect... need feedback
What's your question?
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 7/2/10, 7:08 PM
What do you think the sub panel feeds ? Or is it
a disconnect..?.( breaker )
Old 7/2/10, 7:25 PM
It appears to be a disconnect for something - but not for the service equipment. There may be a simple pull-out, or a fuse block.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 7/2/10, 7:26 PM
Jay C. Murray's Avatar
Jay C. Murray Jay C. Murray is offline
Could you determine what the wiring headed to it looked like when you removed the panel cover under the meter?
I'd Report:
Padlocked electrical box apearantly connected to Main Panel. Unable to access or evaluate. Use and function unknown. Recommend evaluation by licensed electrical contractor
Your Home Inspection & Wind Mitigation Provider
Jay C. Murray
Florida Home & Insurance Inspector Chapter Board Member
Licensed General Contractor & Home Inspector
Serving Port St. Lucie, Ft. Pierce, Stuart, Palm City, Jensen Beach,
The Palm Beaches, & The Treasure Coast
Old 7/2/10, 8:01 PM
Thanks Jeff
Old 7/2/10, 8:37 PM
Robert Meier's Avatar
Looks like a disconnect to me. Did those 90° elbows have removable covers or are they plumbing fittings?
Old 7/2/10, 8:41 PM
They do look like plumbing fittings don't they.
Larry Kage, CMI
231 929 3525
Old 7/2/10, 8:45 PM
Yes they do from the photo but I didn't want to leave anything to a guess. If they are pluming fittings then that should be in the report as well. Even the raceway might be plumbing pipe. In that case it should all be replaced as it's not listed as an electrical raceway.
Old 7/2/10, 8:48 PM
10-4...
Larry Kage, CMI
231 929 3525
Old 7/3/10, 7:56 PM
Gerald C. Wilcox's Avatar
Gerald C. Wilcox Gerald C. Wilcox is offline
Is that conduit (reddish color coming out of the panel) what does that feed and where does it go?
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 7:28 PM
Main Panel vs Sub-Panel and main disconnect? rbassett Electrical Inspections 11 10/24/09 6:16 PM
Electrical for Dummies mcyr Electrical Inspections 16 6/9/08 9:59 PM
