Hello and Happy Holiday's everyone. I am going to check my neighbor's sub panel main breaker that is located in the main panel in the garage tomorrow. It has started to trip on several occasions and shut's down the entire basement and his office. I told him it was probably loose or a bad breaker. I also wanted to test the Temperature of the breaker if it loose to see if it's overheating. I don't normally do this, so what temp would I be looking for on a 100 amp sub disconnect?? any help would be greatly appreciated!!!!!
Thanks, Chris |
Have you looked at the load? It may be a real O/C trip.
cmccann is a non-member guest and is in no way affiliated with InterNACHI or its members.
Translated...It may be a real short in the system that is causing this.
Hi Chuck, hope all is good in southern Michigan. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
ccbrands1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
did they put up any xmas lights this year?
did the issue begin after they did? bad or loose breaker possible...i'd investigate overload issues first, though. temp of the breaker will depend on many factors....manufacturer, ambient temp, etc... Last edited by ccbrands1; 12/28/06 at 9:50 AM.. |
You are going to check the disconnect or OCPD for the load side panel? The disconnect is located in the service equipment? As others mentioned, it's likely there's actually an over-load or short somewhere. Checking the temp of the breaker doesn't tell you whether it's a poor connection or an over-loaded circuit - it will only tell you the temperature. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
I don't know why you'd waste your time doing such a thing. Have him call a licensed electrician.
| Subpanel wired as main panel. | jlybolt | Electrical Inspections | 15 | 5/23/07 4:10 PM |
| Main disconnect at meter instead of main panel. OK? | kshepard | Electrical Inspections | 14 | 11/8/06 6:24 PM |
| Sub panel main tripping? | crichiii | Electrical Inspections | 6 | 9/19/06 10:08 PM |
