![]() ![]() ![]() ![]() ![]() Is this OK. I wasn't sure about this sub panel. The larger one is labeled as MAIN and the smaller one is labeled PRINCIPAL. Any help is appreciated. Thanks. Ian Niquette Square One Home Inspection Markesan WI 53946 www.squareonehomeinspection.com Active Rain Network INACHI Awards Portal Want To Exchange Links? What we've got here is......failure......to communicate.....
Hi Ian, neither panel contains an SEC, so I am guessing that the main disconnect was elsewhere, amking both of the panels neutral & grounds connected wrong, also the feeders to those panels look awfully small. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
On second thoughts the larger panel does appear to be back-fed through the top left breaker making that the main, but it should have a fastener holding it to the panel, if that's the case the smaller panel (being fed by the lowest left braker) is still incorrect.
Looks like the whole thing was "Harry wired" Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 Last edited by gbeaumont; 9/28/08 at 11:08 AM.. |
Thank you. I was thinking the second one was incorrect. Just wanted a second opinion.
Either way, the whole system is wrong and should be brought up to code.
| Electrical for Dummies | mcyr | Electrical Inspections | 16 | 6/9/08 9:59 PM |
