Old 12/30/08, 1:07 PM
Joshua L. Frederick Joshua L. Frederick is offline
Default sub panel verbiage
Could someone please give me some decent verbiage regarding sub panel neutral/ground separation and neutral isolation. Thanks.
Old 12/30/08, 1:22 PM
Jeffrey R. Pope's Avatar
Default Re: sub panel verbiage
I would suggest that you address the specific issue at each panel, rather than trying to "explain" how it should be wired.
Such as;
The neutral conductors are bonded to the enclosure, which is improper and should be corrected - or,
The grounding conductors are not bonded to the enclosure, which is required and should be corrected - etc. . .
It's much less confusing this way.
JMHO
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 8:28 PM
Electrical for Dummies mcyr Electrical Inspections 16 6/9/08 10:59 PM
100 amp Service w/new 200 amp panel mlong Electrical Inspections 10 2/7/08 3:08 AM
Panel Inspection Safety roconnor Electrical Inspections 10 9/24/06 10:02 PM
Bad electrical problem Pest Guy Electrical Inspections 4 1/20/06 10:26 PM
