Go Back   InterNACHI Message Board > Specific Inspection Topics > Electrical
Electrical Contains discussions about electrical systems. This includes outlets, panels, wiring, et cetera.
Old 7/2/09, 9:20 AM
Ralph M. Smith Ralph M. Smith is offline
Default Subpanel issues
Hi Sparkies, I am the 1st to admit that electricity is my weakest area. I would like to know if I have this right and did I get it all.
Ralph M. Smith; CMI, CHI, CI, CEO
S.H.I.R.E. Inspection Services, Inc.
"Your Home is Our Business"
http://shireinspect.com
Find an InterNACHI certified Nebraska Home Inspector (and anywhere else in North America)
Old 7/2/09, 9:36 AM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Subpanel issues
Looking at the mounting screw which is visible in the lower left hand side I would also guess that there may be an issue there , as it appears to not be secured properly .
Were all 4 in place or just 2 kitty corner screws ?
Old 7/2/09, 9:38 AM
Am I seeing shadows or wiring. Where is the double tap?
If the opposite of pro is con, the opposite of progress must be...
Old 7/2/09, 9:55 AM
Robert, all four were in place.
Blaine, Shadows, not a double tap. The top two wires are 14 gauge and the one below is a 12 gauge. The breaker is a 20 amp.
Old 7/2/09, 11:03 AM
Gerry Beaumont's Avatar
Gerry Beaumont Gerry Beaumont is offline
Hi Ralph,
the only real problem in that panel is the grounds and Neutrals on the same bus, as it's a remote panel they should be seperated and the neutrals isolated from the panel box.
Yout "double tap" is the sensing wire for that GFCI/AFCI
there is nothing wrong with 2 cable assemblies in one bushing
Regards
Gerry
Virtue is more to be feared than vice, because its excesses are not subject to the regulation of conscience.
Adam Smith (1723-1790)
NACHI cell 484-429-5466
NACHI02121106
Old 7/2/09, 11:15 AM
Gerry, The 14 gauge wire on the 20amp GFCI/AFCI breaker is OK? 2 wires in the same box opening OK? There is no seperate bar for seperating the ground and neutrals. wrong box? I appreciate your input Gerry, I just want to make sure of all issues. Thanks to Robert and Blaine also.
Old 7/2/09, 11:29 AM
I'd note the wires undersized/oversized breaker and that the neutrals are not isolated or separated.
Larry Kage
231 929 3525
Professional Inspector and Infrared Thermographer serving the Traverse City, Michigan area and beyond.
ITC/FLIR CERTIFIED BUILDING SCIENCES THERMOGRAPHER
ITC/FLIR CERTIFIED LEVEL 1 THERMOGRAPHER
Old 7/2/09, 12:09 PM
Originally Posted by rsmith5 View Post
Gerry, The 14 gauge wire on the 20amp GFCI/AFCI breaker is OK? .
Sorry, brain fart, that should be on a 15amp, my bad
Gerry
NACHI02121106
Old 7/2/09, 12:25 PM
relliott's Avatar
Looks like you caught the issues
Old 7/2/09, 9:08 PM
Jim Port Jim Port is offline
Just to clarify, that bond strap near the neutral buss should have been removed. An auxillary ground buss should have been added/
Old 7/3/09, 12:15 PM
Paul W. Abernathy's Avatar
Send a message via AIM to pabernathy Send a message via MSN to pabernathy
A few things come into mind and I most certainly don't want to MUDDY any waters over bringing up lessons to learn from. Did the OP say if this "Remote" panel was in the same structure or a detached structure as I always hate to assume it.
Depending on the Code Cycle they are in it may not be a violation to have the Case to Neutral connection, but since they DID run the four conductors then it would indeed need to be seperated as Jim and Gerry have pointed out but something to think about for those 2005 and earlier NEC jurisdictions.
Also if this was a detached structure which I again don't know that it is or isn't and I am just kinda grasping at straws here....then a grounded electrode system would also be required....just things to think about.
Another reason I ask this is it is not typical to back fed a breaker in a "sub-panel" in the same dwelling so when we see back fed devices we look for hold down devices and then think...wait a minute it may be a detached structure and then OTHER issues come into play that I wont go into right now....just think about the senerios and it helps you learn....
BTW......the first step is admitting that Electricity is a weak link...now do something about it and take the online quiz, read all you can and ask as many questions you need until your comfort level is raised. Thats what we are here for, thats why people like me and others give "FREELY and WITHOUT MONITARY GAIN" advice to help people like yourself by CHOICE.....as one knowledge is weak but as a group knowledge is STRONG !
Paul W. Abernathy,CMI,CEI,CEPE
NECŪ Consultant/Columnist
www.twitter.com/ElectricalGuru
- ICC & IAEI Certified Electrical Inspector
- ICC & IAEI Certified Electrical Plans Examiner
- Look for my article in the Nov/Dec 2009 IAEI Magazine
- 2007 "Top Gun" Winner - Mike Holt Enterprises
" visit www.TheElectricalGuru.com Today !"
Old 7/4/09, 11:36 AM
Thanks for all the input guys. This message board is by far the best learning tool that I use. Paul, This month I am taking an electrical, continuing ed class for my license renewal requirements. [NY]
Old 7/4/09, 11:40 AM
Excellent.....any education is a SOUND investment in your future. Good luck my friend.
underamped subpanel?? wstafford Electrical 12 5/13/09 6:08 PM
Neutral/ground bond in subpanel gkeene Electrical 2 1/23/09 11:14 PM
Got a letter from ASHI's President today. gromicko General Inspection Discussion 36 2/24/08 1:30 AM
Let's talk ESOP rcooke General Inspection Discussion 231 2/22/08 9:55 PM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
