Old 4/27/11, 4:59 PM
Joe Funderburk, CMI's Avatar
Question Suitable Disconnect?
Note the circuit breaker on the air handler itself. Is there anything that says the disconnect has to be separate from the appliance?
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Need a home inspection in Illinois? Check out InterNACHI's listing of Illinois certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/27/11, 5:16 PM
Robert Meier's Avatar
Default Re: Suitable Disconnect?
Nope. An integral disconnect is permitted as long as it disconnects all of the ungrounded conductors.
Old 4/27/11, 6:09 PM
Please explain why this one does not.
Also, what code to rely on? Could not find it during a word search. Thanks.
Theodore Roosevelt
Joe Funderburk, CMI
Old 4/27/11, 6:55 PM
Jim Port Jim Port is offline
Unmoderated Guest
I believe RM meant the Nope to mean it does not need to be a separate disconnect and that the unit switch is fine to serve as a disconnect.
Old 4/27/11, 7:29 PM
Jeffrey R. Pope's Avatar
NEC 422.34 Unit Switch(es) as Disconnecting Means. A unit switch(es) with a marked-off position that is a part of an appliance and disconnects all ungrounded conductors shall be permitted as the disconnecting means required by this article where other means for disconnection are provided in occupancies specified in 422.34(A) through (D).
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 4/27/11, 7:42 PM
Thanks guys, yes that is what I meant in response to Joe's question "Is there anything that says the disconnect has to be separate from the appliance."
Old 4/28/11, 12:32 AM
Richard L. Overton Richard L. Overton is offline
Is the disconnect fastened to the dead front in such a way as to cause a hazard when the cover is removed?
Old 4/28/11, 1:02 AM
Marc D. Shunk's Avatar
Banned
No. Historically, those are almost always Square D QOU breakers. They clip on DIN rail. They have line and load side lugs. They still present energized terminals to the person who takes off the appliance cover. If you are an employee of an inspection agency, it would be flatly illegal for you to remove that cover without proper training and PPE. Owners, feel free to do as you please.
Main Panel vs Sub-Panel and main disconnect? rbassett Electrical Inspections 11 10/24/09 6:16 PM
50 amp disconnect for 1600sf condo kmccullough Electrical Inspections 5 4/10/07 8:49 PM
A/C Disconnect question rslocum Inspecting HVAC Systems 15 9/21/06 12:16 AM
100 Amp Meter, 200 Amp Disconnect jweinberg Electrical Inspections 8 8/15/06 12:32 PM
Disconnect and Main panel srowe Electrical Inspections 10 6/13/06 7:49 PM
