Old 1/15/11, 12:16 AM
Mark E. Northrup's Avatar
Mark E. Northrup Mark E. Northrup is offline
Default sump pump dedicated outlet GFCI
Hello All
Happy New Year
Does anyone know if nec has anything about a sump pump being on a dedicated circut and also being a gfci outlet.
Or any reason that this should be.
thank you
Mark
House 2 Home LLC
503-602-1420
HomePros@House2HomeLLC.ORG
Protecting Peace of Mind One House at a Time
IAC2 Certified
IR Certified
A favorite place on Google Maps
Need a home inspection in Wisconsin? Check out InterNACHI's listing of Wisconsin certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/15/11, 12:27 AM
Default Re: sump pump dedicated outlet GFCI
Unfortunately, 2008 version required it to be on a GFCI.
Jeff
Jeff Wicklander
Corwick Home Services
Join my business on Facebook
Old 1/15/11, 7:16 AM
Robert Meier's Avatar
There is no NEC requirement for GFCI protection for a sump pump. The 2008 NEC removed the exception for 120 volt non-GFCI receptacles in dedicated spaces in garages and unfinished basements. If the location of the sump pump receptacle requires GFCI protection then you must have GFCI protection. If the sump pump were located in an area where non-GFCI receptacles are permitted then you wouldn't need GFCI protection for the pump receptacle.
Personally I dislike this requirement and would not use a GFCI protected receptacle or circuit breaker for a sump pump. One option would be to use a pump rated for 240 volts and use a 240 volt non-GFCI branch circuit.
Old 1/15/11, 7:34 AM
Roy D. Cooke, Sr's Avatar
I have a gfci protected sump pump .
I put in a watered back up sump pump.
Gfci never dumped but during a power failure the water powered sump sved the day .
You have to be on town water of course .
Home Depot Canada $150;00
Old 1/15/11, 7:58 AM
Bob Elliott's Avatar
Perhaps sumps should not be plug in devices as that would solve the issue.
Make them hard wired.
Old 1/15/11, 11:48 AM
Jeffrey R. Jonas's Avatar
That would be nice. I see them unplugged all the time so the homeowner can plug in their dehumidifier, or other such thing.
Old 1/15/11, 3:37 PM
Furnaces are not required to have GFCI because they are hardwired.(condensate)
Old 1/15/11, 4:03 PM
I thought this was a "sump pump" thread!
Old 1/15/11, 4:06 PM
Bob... as in "portable DEhumidifiers. Ya know, that thing that homeowners with basements use!
Old 1/15/11, 4:23 PM
Sorry to confuse anyone as I was simply trying to give an example as Furnaces are hardwired.
Junction box and switch rather than a plug.Also they are associated with water but you would never need a GFCI because they are switched.
Perhaps a bad metaphor.
Old 1/15/11, 4:34 PM
Mark -
I would leave my sump pump on a dedicated outlet WITHOUT a GFCI (don't wanta find out my GFCI tripped accidently when I'm 6" deep in water on my finished basement floor).
Old 1/15/11, 4:36 PM
Originally Posted by dbowers View Post
Mark -
A legitimate concern but the NEC doesn't really care if the device trips and you're underwater because of it. The code requires that the receptacle be GFCI protected if it's installed in an unfinished basement or garage.
Old 1/15/11, 5:58 PM
Stephen W. Stanczyk's Avatar
When I see the crawl space sump pumps around here, most are non GFCI protected.
I recommend they be GFCI protected but let the client know that the best place to put the reset is in the main family room near the tv. If the light comes on, they know they need to reset the pump. Don't like having the resets in the now flooded crawl space.
Stephen Stanczyk
Old 1/15/11, 8:53 PM
John Gromkoski's Avatar
John Gromkoski John Gromkoski is offline
Why only in unfinished basement? Why not in finished basement? What's the theory behind this?
774 Manor Road
Staten Island, NY 10314
718-514-3393
Old 1/15/11, 9:30 PM
Marc-Andre Beauchemin's Avatar
Marc-Andre Beauchemin Marc-Andre Beauchemin is offline
I agree with stephen, I find it ridiculous when installed in a out of reach area. I prefer GFCI be located visible in the family room having it protect the sump pump connect to the protected plug.
A GFCI can protect up to 12 outlets. Then for this one, two could do the trick and avoid forgetting to reset it.
basement floor Unregistered AskNACHI.org Inspection Questions Forum 4 9/15/10 1:23 AM
Sump pump requirements Matthew Klein Plumbing Inspections 0 12/30/09 3:53 PM
sump pump and the GFCI in a crawlspace jfrederick Electrical Inspections 18 1/2/09 11:13 PM
