New construction. None of the tested Square-D breakers would trip with a Sure-test. Got a strange read-out. What do you think?
| Need a home inspection in South Carolina? Check out InterNACHI's listing of South Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
You didn't wait long enough between tests. After a series of tests, it needs to cool down. Manual calls for 20 seconds between tests to dissipate heat.
Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
Thanks Stephen.
None of the AFCI's tripped however. I've heard that the test button is the accepted test method, but when I can't get them to trip using the Sure-test, I write it up. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Did they trip with the test button?? . That is the recommended way to test Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Have you got a updated one/ we had problems with a couple of manufactures Siemens was one . Ideal had to update the unit
Does the test button trip the breaker? If so how can you write it up? Isn't the TEST button the prescribed testing method set forth by the manufacturer? |
"An arc-fault circuit interrupters protecting the bedrooms and living areas do not trip when tested using a Sure-Test circuit analyzer, and should be evaluated by a licensed electrician. AFCI receptacles are life saving devices but may fail or be defective from the manufacturer. Any claim that the only reliable test is by using the breaker's integrated test button should be substantiated with written documentation from the manufacturer." “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com Last edited by jfunderburk; 6/7/11 at 9:38 AM.. |
The only UL recognized test method is the built-in test buttons. You are not using a tester, it is more properly called an indicator.
To write up something when the proper procedure works would be a poor call IMO. |
From the link...They recommed using the integral test button. Can the underlined/bolded always be verified by the home inspector? 1. At the panel, operate the test button on the AFCI breaker installed in the branch circuit. a. If the AFCI breaker trips, reset the breaker to restore power. b. If the AFCI breaker does not trip, verify proper installation of the breaker. If the installation is correct and the breaker still does not trip, replace the faulty breaker. 2. Then, check each outlet on the branch circuit for proper wiring configuration by using the LEDs on the 61-059 tester. 3. Go to the furthest outlet on the branch circuit from the panel and conduct an AFCI trip test with the tester. a. If the breaker trips, then use the tester to check that each outlet on the branch circuit has been de-energized to confirm that the outlets are on the same AFCI branch circuit. b. If the breaker doesn’t trip, then the branch circuit may have excessive line impedance (i.e. voltage drop) from undersized wiring, loose wire connections and/or faulty wiring devices. The SureTest® model 61-165 can be used to further identify the source of high impedance on the branch circuit. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
There are certain types of AFCI breakers that do not trip when the SureTest is used, although the AFCI function is operational.
As long as the circuit is opened when the internal test button on the breaker is used, the AFCI is considered functional. The readings on your SureTest show "caution" (triangle with exclamation), "don't operate" (circle with line), "over heated" (thermometer) and "wait" (hour glass) - in other words STOP! IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
I thought the appropriate way was to test at the breaker itself??
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
Same if your Tester does not trip a GFCI and the Test Button does trip the Circuit, it is not a defect. |
I carry 3 GFCI testers in my tool kit from the small $10 type to the original Suretest I bought in 1985. If none of my testers will trip a GFCI and the test button does, I call it as a defect!! Just being safe......... when 3 testers that are designed to "create a ground fault condition" do not cause a trip, I'm assuming the GFCI unit will not trip when a real one occurs!
| AFCI breakers | straylor | Electrical Inspections | 3 | 1/6/11 3:59 PM |
| AFCI breakers | cbono | Electrical Inspections | 15 | 2/27/08 1:33 PM |
| Stacking AFCI, GFCI breakers | abolt | Electrical Inspections | 6 | 4/17/07 10:57 AM |
| FPE Panel - Do you open them up? | menser | Electrical Inspections | 11 | 2/7/06 6:31 PM |
