This is the electrical service for a 4,000 sq. ft., 46 year old house that I inspected yesterday. Maybe I'm a virgin, but I've never seen anything quite like this in a residential setting. Besides these panels, there were also 3 large sub-panels in other parts of the house.
Did have one question, how do you folks feel about the tags in the panel in the last picture? Mark MD HI Lic # 30090 BPI Certified Building Analyst PA DEP Radon Cert # 2457 Certified Home Energy Tune-uP Inspector
There was a spirited discussion on your question recently. Follow the link:
http://www.nachi.org/forum/showthrea...highlight=tags |
thanks, Michael! Mark MD HI Lic # 30090 BPI Certified Building Analyst PA DEP Radon Cert # 2457 Certified Home Energy Tune-uP Inspector
bkelly1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
800 or 1200 amp service?
bandag is a non-member guest and is in no way affiliated with InterNACHI or its members.
Mark, what kind of business were they operating there?
Would you believe that it was just 400 amp. Mark MD HI Lic # 30090 BPI Certified Building Analyst PA DEP Radon Cert # 2457 Certified Home Energy Tune-uP Inspector
No business that I'm aware of, and not even a workshop or anything like that. Just a large, 1960 era contemporary private residence, with a lot of eccentric electrical stuff. There's a lot of lighting with multiple switches to turn every light on and off from various locations and all of the light switches are on relays. Just not your typical three way switches. A security system , of course. There's some type of driveway heating system to melt the snow. Apparently they originally hung their clothes on a clothes line in the basement and there's a large exhaust fan to pull the moisture out of the basement. Originally it was all Radiant ceiling heat before they installed some heat pumps and about four of the panels on the upper right contain relays for that. A swimming pool. Just a lot of stuff. The large commercial type main breakers just kinda surprised me. Mark MD HI Lic # 30090 BPI Certified Building Analyst PA DEP Radon Cert # 2457 Certified Home Energy Tune-uP Inspector
ksaunders is a non-member guest and is in no way affiliated with InterNACHI or its members.
How did you write this up? the pics are small but it would appear to be above my level of expertise.
Regards Kevin |
I regularly see 400 amp service in this area. Large homes, larger service.
I have eve started to see 480 amp, commercial main disconnects in some large homes with 3 or 4 load side distribution boxes. Better bone up on commercial electrical installations, that is where these guys are going. What a time to be an inspector. Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
Even so, all of that is nowhere near needed for a simply 400amp install.
I have seen a 1200 amp service in a house. And I have installed more 1200 and 1800 amp installations than I care to remember. Not to mention some much larger than that. There is nothing like working on a motor in a factory that is 3600volts. |
Was your clients last name "Frankenstein"?
:P Brian R. Sumpter First Call Inspections Proudly serving most Bay Area Counties www.firstcallinspections.com |
Ensure they size according to 310.16 and understand even in residential....using commercial equipment...that being OVER 400A has some things they need to be aware of... Paul W. Abernathy |
Basically, I just treated it like any other inspection and focused on one component at a time. I actually did open up every panel. I don't wear a watch when I'm on an inspection, but I think that I spent about 1 1/2 hours just looking at all of the electrical panels. Actually, the big ones, though they look intimidating, are just big metal boxes with 2 big fuses in each of them, with a throw switch (yea, i know, that's simplistic). And the several panels of relays, basically made sure they worked, no scorching, no clattering, etc. I used to sell spas/hot tubs and worked on them some. The relays were pretty much the same as I would see in older spa packs. All the sub panels I just treated like any other sub. I even opened up the main disconnect. As you commercial guys probably know, to open up a panel like that, you have to throw the switch off. I thought about that for a long time and considered what, if any consequences there might be to shut off all of the power to the house, but decided what the heck, in for a penny in for a pound ( or whatever the saying is). I put on my head lamp, turned on my second flashlight, and went for it. And I lived to tell the tale </IMG> Mark MD HI Lic # 30090 BPI Certified Building Analyst PA DEP Radon Cert # 2457 Certified Home Energy Tune-uP Inspector
| New Washington Legislation Submitted | gdomagala | Legislation, Licensing & Legal Issues for Inspectors | 294 | 2/10/08 1:20 AM |
| Massachusetts Board of Registration of Home Inspectors | jtedesco1 | Legislation, Licensing & Legal Issues for Inspectors | 0 | 2/14/06 3:38 AM |
