Old 9/1/06, 12:13 PM
lhoffman lhoffman is offline
Please Note: lhoffman is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Tenant access to main disconnect in apartment bldg?
The IRC states that occupants must have access to disconnecting means - would that mean that in an apartment bldg where the main panel and disconnect is in a locked utility room the door should remain unlocked in order for the residents to access and turn off the main electrical disconnect? Also, each unit of the building has a subpanel, which is located in a closet. The building was built in the 40's, so I am wondering if the panel's locations in the closets is grandfathered?
Any advice? Thanks!
Old 9/1/06, 12:25 PM
Jeffrey R. Pope's Avatar
Default Re: Tenant access to main disconnect in apartment bldg?
This is the exception for the service disconnect. . .
Exception: In a multiple-occupancy building where electric service and electrical maintenance are provided by the building management and where these are under continuous building management supervision, the service disconnecting means supplying more than one occupancy shall be permitted to be accessible to authorized management personnel only.
The requirement for location of OCPD's has always been that they should "not be located in the vicinity of easily ignitable material," but they have recently added the "specification" about "clothes closets."
Overcurrent devices shall not be located in the vicinity of easily ignitable material, such as in clothes closets.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 9/1/06, 12:34 PM
Thanks Jeff.
Do you know where I can find the update on the clothes closets so that I can show my client the reference? Also, I assume that since the bldg was built in the 40's it is grandfathered compliant?
Old 9/1/06, 12:44 PM
2002 NEC 240.24(D)
It was not specifically prohibited in earlier editions, so it has been "allowed" for many years. Common sense however, would dictate that it has never been "compliant."
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 9/1/06, 12:54 PM
Thanks much for the reference and help Jeff !
Main disconnect at meter instead of main panel. OK? kshepard Electrical Inspections 14 11/8/06 7:24 PM
Disconnect and Main panel srowe Electrical Inspections 10 6/13/06 8:49 PM
125 AMP Main Disconnect hgordon Electrical Inspections 5 5/18/06 11:20 AM
No main disconnect ecox1 Electrical Inspections 15 3/7/06 10:59 PM
Main Disconnect Manufactured Home dbreen Electrical Inspections 1 3/4/06 1:42 PM
