Is it possible for one plug( of the two) for a 110, afci, or gfci to be incorrectly wired? or are both always going to be consistent with each other?
If you trip one Gfci plug (of the two) correctly is the second plug going to automatically trip correctly? Richard W. Washington, owner RW Home Inspections, Inc. www.RWHOMEINSPECTIONS.com Texas Real Estate Commission (TREC) Professional Inspector License #7238 Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter InterNACHI member since 2004 Based in Katy, serving Houston and all surrounding communities |
| Need a home inspection in Michigan? Check out InterNACHI's listing of Michigan certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Richard,
I am not sure I understand your question so please forgive me if my response is not what you are looking for. On a typical GFCI device you will have a line and load marking. If the GFCI device is wired properly it will function regardless of the polarity downstream of the device. If someone wires a receptacle improperly on the load side of the GFCI then it will read reverse polarity in your tester for that given device but as far as the GFCI device is concerned it will trip properly regardless. Now, I am not sure if that is what you are asking...but I gave it a shot. Paul W. Abernathy |
I'm guessing that you're referring to a duplex receptacle?
No not necessarily, they could be wired up differently or they could have separated dedicated circuits for each plug. Quote:
Or in case I miss understood this question, it all depends on how it’s wired up. Last edited by growden; 11/24/11 at 11:23 AM.. Reason: Updated with additional comment: |
My question would be why you would have more than 1 GFCI on same circuit.
My last 2 inspections had not 2, not 3, not 4 but 5 GFCIs on the same circuit. The bathrooms were connected to the kitchen. I scratch my head a while and thought I would never be able to find the reset button. Where there is a Will there is a Way! Will Misegades TREC# 10465 RedFish Home Inspections www.redfishinspections.com |
I apologize but my wording is not very clear. On a 110 outlet you can plug in, let's say, 2 lamp cords. Can one of the two plugs be, let's say, properly wired and one a hot/neutral reverse? I am just talking about one outlet.
I am essentially asking the same thing for a GFCI. Let's say the top plug will trip the circuit (with a GFCI tester) does that automatically mean the bottom one will too. I am just talking about "within" one outlet. Hope that helps to clarify. Happy Thanksgiving BTW! Richard W. Washington, owner RW Home Inspections, Inc. www.RWHOMEINSPECTIONS.com Texas Real Estate Commission (TREC) Professional Inspector License #7238 Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter InterNACHI member since 2004 Based in Katy, serving Houston and all surrounding communities |
An HI is a non-member guest and is in no way affiliated with InterNACHI or its members.
[QUOTE=rwashington;844599]I apologize but my wording is not very clear. On a 110 outlet you can plug in, let's say, 2 lamp cords. Can one of the two plugs be, let's say, properly wired and one a hot/neutral reverse? I am just talking about one outlet.
It can be physically done but would be a very rare event caused by an inexperienced person trying to do something like having one half of a receptacle switched remotely. I am essentially asking the same thing for a GFCI. Let's say the top plug will trip the circuit (with a GFCI tester) does that automatically mean the bottom one will too. I am just talking about "within" one outlet. QUOTE] Yes, if it's wired correctly internally. You can't split a GFCI receptacle like a regular receptacle. Last edited by An HI; 11/25/11 at 4:23 AM.. |
Jim Maryland Home Inspection Services Inc. www.MarylandHomeInspectionServices.com State of Maryland License# 31141 Virginia License#3380 000468 National Association Of Certified Home Inspectors ID: NACHI10101807 International Association of Certified Indoor Air Consultants (IAC2). Certification # IAC2-02-0919 Maryland Home Inspectors In Gaithersburg, Rockville, Germantown, Bethesda, Potomac, Also All of Northern Virginia and Washington, D.C. |
Q: Do you really know what GFI stands for ??? A: Good Fricken Idea Jim Maryland Home Inspection Services Inc. www.MarylandHomeInspectionServices.com State of Maryland License# 31141 Virginia License#3380 000468 National Association Of Certified Home Inspectors ID: NACHI10101807 International Association of Certified Indoor Air Consultants (IAC2). Certification # IAC2-02-0919 Maryland Home Inspectors In Gaithersburg, Rockville, Germantown, Bethesda, Potomac, Also All of Northern Virginia and Washington, D.C. |
A GFCI (Ground Fault Circuit Interrupters) circuit breaker provides protection against overloads, short circuits and ground faults. It detects very low levels of electrical current leaks (ground faults), and acts quickly to shut off power, preventing serious shock. GFCI receptacle measures the difference in current between the hot and neutral lines using a differential transformer. If there is no outside leakage path, the currents will always be identical, and thus the difference would be exactly zero at all times. GFCI receptacle trips when the difference in current is around 5 ma. |
SOOO, I had a good workout and I wrote it up. Anybody would know why/how this would happen? Where there is a Will there is a Way! Will Misegades TREC# 10465 RedFish Home Inspections www.redfishinspections.com |
Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
| Mold Inspectors in Coeur d’Alene, ID 83815 | rspriggs | Ancillary Inspection Services & Additional Topics | 15 | 1/3/12 1:14 PM |
| Washington State Inspectors - Your Deadline Is Near | Mike O'Handley | Legislation, Licensing & Legal Issues for Inspectors | 54 | 4/14/10 9:15 PM |
| Well Water Testing in Coeur d’Alene, ID 83815 | rspriggs | Ancillary Inspection Services & Additional Topics | 0 | 1/9/09 3:31 AM |
