How are you testing 2 blade ungrounded receptacles?
Rick Strand, CPI CAHPI Associate Strand Home Inspections Inc. Calgary, Alberta, Canada Serving Calgary, Okotoks, Airdrie, Chestermere and Cochrane Alberta
| Need a home inspection in Pennsylvania? Check out InterNACHI's listing of Pennsylvania certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
If they're polarized the only thing that you can really check is to see if they're wired correctly.
Use your non-contact voltage tester. Older receptacles don't have a dedicated neutral slot, but newer non-grounding type receptacles do.
Just make sure to set the sensitivity on low to see which side is hot.
Get a 3 prong to 2 prong adapter and you will see that most of these have lost the tension and need replacing.
B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
J.Szczesny 4 Seasons Home Inspections Washington State Inspector # 711 800 5th Ave #101-385 Seattle, Wa 98104 (206)391-0285 online @ www.4seasonsinspects.com email @ info@4seasonsinspects.com toll free cal @ 866-512-9972 "For the best protection, get the right inspection" |
Fantastic info guys - thanks!
Thats what I use also.
Plus I check that touching the adapter tab to the faceplate screw gives me a "good ground" indication on my GB receptacle tester ... or it gets written up as a safety concern, since using the 3-2 adapters with an ungrounded outlet/box is hazardous. JMO & 2-Nickels Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
Use a two prong neon 120/240 tester (super cheap) in conjunction with your non-contact voltage tester. You can check for current and polarity.
Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
Great tip Chuck. Do I need to take my shoes off first?
Eric W. Augustin A1 Certified Home Inspections If you can't explain it simply, you don't understand it well enough. Albert Einstein
| Mold Inspectors in Coeur d’Alene, ID 83815 | rspriggs | Ancillary Inspection Services & Additional Topics | 15 | 1/3/12 1:14 PM |
| Ungrounded Electrical Receptacles. Another inspection article from InterNACHI. | gromicko | Electrical Inspections | 0 | 11/9/10 4:22 PM |
| New inspection article: Ungrounded Electrical Receptacles | inxil | InterNACHI & RealMatcher Blogs | 0 | 11/9/10 3:30 PM |
| False grounds & testing receptacles | dmacy | Electrical Inspections | 1 | 8/27/09 11:03 AM |
