Here are a couple of pictures that concern me. The first one shows the service connected to the main disconnect. The insulation was stripped correctly, but there is a significant amount of exposed conductor. Just wondering if there are any standards for this.
The second picture shows an additional problem. Not only is the length is excessive, the cable has been doubled and has visible corrosion. The corrosion is enough for me to call it out. Greg Liebig, Owner Sheboygan Wisconsin Home Inspector 4-Square Home Inspections, LLC Where Knowledge will put your Mind at Ease © Sheboygan, WI 53081 (920) 451-4646 www.sheboyganhomeinspector.com www.4squarehi.com Like Us on Facebook Follow Us on Linked-In |
| Need a home inspection in Wisconsin? Check out InterNACHI's listing of Wisconsin certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Hello Gregary:
You can tell by the cut that a certified electrician did not do this. Yes there are requirements for proper amount of sheathing showing. However we cannot mention what a code allows unless we are code officials and some cases the code will not. Some breakers have written info on the proper installation including length to remove for sheathing. Rule of thumb is no more then a 1/4 inch passed connection but only for visual to see if it is loose. THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
As far as the lug is concerned this is no different than a double tap.
If you don't mind ( I know I am not here much anymore ) I would like to comment on the torque of the breaker. I notice that the one with the corrosion has a set screw that is not turned into is setting as much as the one beside it....would lead me to think the conductor is loose, on load arcing takes place which adds to the problem.
Now I don't know this for fact...it is only an observation but notice the number of threads on the black conductors termination lug than on the red one. Sure looks like it was not properly torques to me...and to be honest with you that can be a problem. As was mentioned before it would be nothing different than a double lug for your review BUT with the corrosion and possible torque ( which can lead to a safety issue so don't feel bad about ASSUMING in that case) ...have it looked at as I also see discoloration around the plastic ( ps. Plastic does not corrode) so something else is going on and my guess would be a loose connection as well. Again....I hate commenting via pictures but it would cross my mind....just a thought. Paul W. Abernathy |
Stephen Douglas is a non-member guest and is in no way affiliated with InterNACHI or its members.
Is there anything to be said about the bottom breaker. Set screw is turned all the way in, almost counter sunk, and the wire looks like it should be in my chevy truck.
Stephen |
| Short circuit failures with 12/3 NM-B cable and NM clamp connectors | pabernathy | Electrical Inspections | 10 | 4/17/11 1:43 PM |
| A Mission to Change the Standards - Let's Debate | krichardson | Miscellaneous Discussion for Inspectors | 74 | 12/19/07 8:29 PM |
| Did you KNOW this about NM Cable? | pabernathy | Electrical Inspections | 0 | 12/19/06 8:46 AM |
| Texas Warranty Inspection Standards | badair | General Inspection Discussion | 5 | 9/30/06 5:12 PM |
