I was wondering if anyone knew of a tool, exact name please, for determining the size of a wire for instances where no lable is visible? Some of these 4, 6 and 8 get hard to tell apart, especially in older wiring or wires with thicker insulation.
I have been searching the internet and I can't find anything. |
Until they are comfortable guaging wire some inspectors will go somewhere (big Box store< etc.) and buy a short piece of each wire size with the size on it to carry with them on inspections.
I have carried samples for years just in case. I'm pretty good at wire sizing, however sometimes, even with samples in hand, it gets difficult. I currently have to figure out if a wire is #4 or #6. The wire is about 30 years old and has very thick insulation which makes it look a lot bigger than it is.
Anyhow, I was hoping there is some sort of tool for helping with the sizing. |
When I first started out, I made this - I still use it, from time to time.
For anyone who might want a sizing tool, I finally found one.
www.professionalequipment.com Item #E659 |
Would not the simple wire stripping tool work? It does stripp the wire casing and not the wire, right? Tells you what size right on the tool.
Just a thought. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
That would be:
http://www.professionalequipment.com...l-accessories/ Looks pretty tough to use that safely a panel, though.... |
Lookie....
The only SURE way to get it right is with practice and experience. The slip over or side guages simply can be wrong as insulation varies from type to type. The best method is to visit the supply house or supply store and get familiar with the different sizes....and I STRONGLY suggest making a CHEAT tool as Micheal has made.....really helps you visually when looking in the enclosure. Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
tom |
I found what he tried to use. http://www.romazone.com/images/wire_gauge_tool.JPG As you can see you need to slide it over the bare conductor. With live breakers, and close together, you can short out several wires at one. Wow what a pretty shade of blue. tom |
I carried a plastic caliper for a while and a card that had the sizes.
| Nice Report on AL Wire Terminations - Enjoy | pabernathy | Electrical Inspections | 0 | 7/2/07 1:35 PM |
| Proper Marr Connectors for Aluminum Pigtails | jskrypka | Canadian Inspectors | 4 | 3/25/07 11:41 PM |
| Starter Inspector's Tool Bag for sale. All items are in almost new condition. | gromicko | Miscellaneous Discussion for Inspectors | 0 | 3/12/07 1:21 AM |
| wire gauge / breaker rating | jweinberg | Electrical Inspections | 19 | 7/16/06 5:36 PM |
