Home had a mid 60's fuse 100 amp service. I had a difficult time inspecting as the panel was in a closet behind a picture. There are 2 pics showing the closet and framing, shelving.
I noted the closet & clearance issues. The home had mostly 2 wire but all the receptacles where indicating they where grounded. I double checked with the sure test. I didnt see any conduit. Why are these showng that they are grounded. I also thru in a pic of the spagetti wiring in attic. The knob & tube was special as well. FIRE SALE |
Your last picture shows the grounding conductor, which was added to the original two-wire K&T (poorly, I might add).
interesting connection on the last picture in regards to the EGC....last I checked K & T did not come with a EGC....and you should not splice a conductor WITH a EGC onto a circuit that has no EGC....
Paul W. Abernathy |
Bootleg ground?
Like this pic I pilfered from somewhere: InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
I would have said the same Larry, if he hadn't checked it with the SureTest. . .
Sorry david....I did not answer the other part.....they are showing grounded possibly because someone went and individually grounded each receptacle to a grounded source.
Otherwise it could not be a bootleg because you used a suretest and it would detect that effect. Now could it be that someone strung a EGC around like the last picture in the set....and everything is connected to that and then all the receptacles have been updated with NM cable with ground...and done like the last picture....quite possible....... dont like it........ I would defer.......something smells here and I WOULD love to be the electrician you call to look it over.....but alas...too far of a commute. Did you pull the panel....got any pictures from the inside of those panels...showing if their are EGC's present and so on....might tell us more. Paul W. Abernathy |
Paul W. Abernathy |
Hey Larry...I have had my 65-155 for a few years now.....and still going strong....worth the investment and the ends can be replaced as well if needed.
Paul W. Abernathy |
Hi to all,
That is the most screwed up installation onto K&T that I have ever seen, I thought I had just about seen it al but adding a 3rd conductor to support the ground on an old K&T circuit thats a first. BTW, great call Jeff, I had to look at the picture several times before I got what had been done. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
That grounded K&T looks pretty "real". It has the same style knobs and loom. I wonder if the electrician who installed the original did think a ground was a good idea and pulled one in along with the 2 circuit conductors.
It wasn't the usual way to install K&T but I can't think of a reason it wouldn't have been legal. I agree the Romex guy could have used a bug or some solder to make his taps. Makes you wonder what is under that tape huh? |
Problem is I flitched it of someone even better, but forgot to put the attribution on it at the time. it is a great image Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
I found one in my father in laws house a couple weeks ago that made me say huh. I pulled out the receptacle in the bathroom and it was pigtailed with bare wire, all 3. Fortunately I am not a "he man" who works live when I don't absolutely have to so it was turned off at the breaker.
I wish I had a camera but you get the picture. I guess the installer ran out of insulated wire. The amazing thing was this was a GFCI and the box was still over wire count. I don't have a clue how he got all of that bare wire in there without shorting something, even with a plastic box. |
jschulte is a non-member guest and is in no way affiliated with InterNACHI or its members.
I can't imagine the time they would have spent installing new tubes to run the grounding conductor. Would have been easier to just run romex. There must have been another circuit there that they disposed of to make room for the grounding conductor.
| GFI not grounded | rtruluck | Electrical Inspections | 14 | 3/7/07 11:02 PM |
| So...Do you think THIS panel is Grounded? | pabernathy | Electrical Inspections | 3 | 1/22/07 7:52 PM |
| opinions on GFCI outlets for non grounded oputlets | jmerritt1 | Electrical Inspections | 23 | 5/11/06 7:22 PM |
| Electrical Inspection Training for Home Inspectors | jtedesco1 | Inspection Education & Training | 6 | 4/27/06 10:43 PM |
