I recently ran into this auxillary electrical panel in a house built in the 1940s. It did not seem to control anything at the property (although some fixtures were removed because it was a foreclosure). I am curious how many other people have seen one of these panels before and what it controlled.
All thoughts will be greatly appreciated. Thanks Jonathan Jonathan N. Leahy President A Rock Solid Home Inspection, LLC. www.arocksolidhome.com 303-718-7779 US EPA Certified Asbestos Building Inspector State of Colorado Asbestos Building Inspector Residential Home Inspections, Asbestos Inspections, Radon, Mold Inspections |
Did you pull the cover? It may have been bypassed.
It looks like a 1940's (or thereabouts) panel. The residence may have been rewired. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
don't twist yourself up about it. It's an old XO panel. If there are no visual hazards, let it pass
What does "XO" mean Marc.
Better Yet.....here is a picture of the XO type breakers just for everyones reference...
![]() Found some info on these for you all as well.....well before MY time....I heard someone make reference somewhere to a "recall" but I doubt it... As for comments to your clients...I would mention it is an older style and breakers can be hard to find if needed so they need to be aware of replacement costs if needed. While not a defect it is your obligation to your clients to inform them about systems that are older in nature and possible costs associated with replacement or servicing. Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year Last edited by pabernathy; 1/9/09 at 2:16 AM.. |
Im with Jeff about pulling the cover & the thought that it may be bypassed...Did you pull it or not? These forclosed homes are somewhat scary when you do this because you just never know what kind of remodeling they did, or first and foremost what kind of vandalism/booby traps that they did.
Thank you everyone for your thoughts and input. I did advise my client that it is an older style. Based on some other electrical issues identified and the fact that the client was planning some renovations, the client asked that I not pull the cover. They just added it to the punch list for the electrician to take care of.
Jonathan N. Leahy President A Rock Solid Home Inspection, LLC. www.arocksolidhome.com 303-718-7779 Residential Home Inspections, Radon Testing, Mold Inspections |
mamills is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hi Guys. I have been reading this website for quite a long time, with great interest. This is my first time to post anything here, and I hope I will not come off as a smart-aleck, since this is certainly not my intention. I have collected a great many old electrical devices over the years, and I have several breaker panels of the type shown here. This particular model is a "Multibreaker" style, meaning that the electrical mechanism inside was manufactured as a single unit that contained two, three or four breakers, and could contain, sometimes as many as ten "units", of breakers. They were manufactured by Cutler Hammer and Square D. They worked quite well, but the inherent problem was that if one breaker failed (as they all do on occasion), you could not replace just the one breaker - the entire unit would need to be replaced. One interesting fact about this little panel, and something to beware of, is that the breaker unit is attached to the cover, not mounted to the interior of the box. So, if you remove the cover screws, you may wind up with a live circuit breaker unit in the palm of your hand. Hopefully, as other have suggested, this little box will have been bypassed with something more up to date.
Mike Mills Last edited by mamills; 1/9/09 at 3:35 PM.. |
Hi Mike,
Thanks for the additional information. Jonathan Jonathan N. Leahy President A Rock Solid Home Inspection, LLC. www.arocksolidhome.com 303-718-7779 Residential Home Inspections, Radon Testing, Mold Inspections |
Rollie Meyers is a non-member guest and is in no way affiliated with InterNACHI or its members.
That is a old Multi-breaker panel, it predated the XO breakers and is of 1940's vintage.
Edit to add, did not read whole thread so did not notice mamills post. |
| Thoughts: Combustion Air Vent | pdoane | Inspecting HVAC Systems | 1 | 9/26/08 2:41 PM |
| Thoughts on this panel | Danny Castellano | Electrical Inspections | 8 | 8/22/06 8:09 PM |
