Old 6/8/11, 4:55 PM
Charley L. Bottger's Avatar
Default Three times a charm
I inspect FP panels almost on a daily biases and If I must say so I am dam good at it practice makes perfect.
Here is an example of a bad one found recently. I do not condemn just based on the name Federal Pacific I judge each panel independently.
This panel was inspected in January by another inspector and he just condemned based on the name which in turned brought out the electrical contractor who inspected it again and put in writing the panel was just fine.
These first two inspections were brought about as the result of a re-location company purchasing the property my inspection was for a perspective buyer. I load tested the panel with in house circuits and built in appliances and exceeded the 80% rule again. The top left breaker was for the cook stove rated at 50 amps the cook stove drew 49 amps and tripped the breaker but by looking at the breaker could not tell it was tripped. So after 3 inspection this home appears to be getting a updated panel.
My client was very happy and after speaking with the selling RE agent I could tell by the sound of her voice which was very quite she was not to happy with the outcome. How do I know this just from the tone of her voice I have been sleeping with her for almost 43 years yes all is disclosed up front and on the table
three-times-charm-1921-el-camino-pc-6-8-11-048.jpg   three-times-charm-1921-el-camino-pc-6-8-11-049.jpg   three-times-charm-1921-el-camino-pc-6-8-11-042.jpg   three-times-charm-1921-el-camino-pc-6-8-11-108.jpg   three-times-charm-1921-el-camino-pc-6-8-11-114.jpg
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Need a home inspection in Massachusetts? Check out InterNACHI's listing of Massachusetts certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/8/11, 5:04 PM
Robert Meier's Avatar
Default Re: Three times a charm
What's the 80% rule? And at what temperature do you consider there to be a problem?
Old 6/8/11, 5:09 PM
80% of the rating of the panel the 100 amp panel should not carry more than 80 amps. I start looking for problems when the temp is 30 degrees above ambient of the panel also I look for an un-balanced load temp wise on a 220 volt double pole breaker both legs should be almost the same in temp
NACHI Member
State License # 130
Old 6/8/11, 5:19 PM
Joe Funderburk, CMI's Avatar
Charley, are you a licensed electrician?
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 6/8/11, 5:22 PM
Nope a visual inspection only camera in hand with amp meter Joe don't start that SOP crap with me we both know better
NACHI Member
State License # 130
Old 6/8/11, 5:26 PM
I would question the use of 80% as a rule. Sounds like a good guideline but it's not supported by the NEC. A panel can be loaded to 125% of it's continuous load plus 100% of it non-continuous load. In a dwelling just about every load is non-continuous with the exception of some lighting loads. A cook top on a 50 amp circuit running at 49 amps is OK according to the NEC.
Old 6/8/11, 5:32 PM
Until it trips at 49 amps
NACHI Member
State License # 130
Old 6/8/11, 5:34 PM
Yes that definitely would be a problem. Ususally inverse-time CB's can operate slightly above their rating for quite some time before tripping.
Old 6/8/11, 5:40 PM
So Robert you are telling me say take a 200 amp panel in today's world and load that baby up to 200 amps continuously full load and that is perfectly fine. According to NEC
NACHI Member
State License # 130
Old 6/8/11, 5:46 PM
No, that would be 200 amp non-continuous. The NEC definition of continuos load is that it is operated at it's maximum ampacity for 3 or more hours. So if you use your range as an example it is permitted to operate at 49 amps on a 50 amp circuit because it will never operate at it's maximum for 180 or more minutes.
Article 100
Continuous Load. A load where the maximum current is expected to continue for 3 hours or more.
Old 6/8/11, 5:57 PM
The 87.9 amps on the 100 amp breaker was what my reference was about and the 87 amps could be in use for many many hours especially on a heavy cook day like thanksgiving. I have never been questioned about exceeding the amp draw by 80% for extended time or the capabilities of extended time.
The breaker tripping on the cook stove at 49 amps within 30 seconds of turning the appliance on was just icing on the cake
NACHI Member
State License # 130
Old 6/11/11, 12:15 PM
Lets also not forget that a conductor as listed in Table 310.15(B)(16) in the 90 degee column is rated for that ampacity continuously....and the temperature rating of the column is exactly what the conductors insulation is rated for...continuously. Now, the reason we limit the ampacity to an 80% value is due to the limitations of the terminations to Overcurrent Devices as prescribed by UL for the device. I can load up a conductor at it's full ampacity for 2 Hours, 59 Minutes and 59 Seconds....and everything is fine. The moment it gets to 3 hours or more....we got a problem.
Notice that THHN in as limited to 75 degrees due to terminal ratings has an ampacity of 200A for a 3/0 CU. Notice the acceptable temperature of the conductors at that degree rating...167 degrees F. Without going into too much detail as I would find it hard to explain it here....it would not be a problem to see a conductor with a temperature not exceeding that value.
Don't want to get too technical....just want to kinda explain it just a little.
Paul W. Abernathy
Old 6/12/11, 8:57 AM
Robert J. OConnor's Avatar
the electrical contractor ... inspected it again and put in writing the panel was just fine.
WOW ... ... not many sparkies out there willing to put their license on the line for an FPE panel with known problems. Probably isn't aware of the issues. Put this link in your reports ... www.inspectapedia.com/fpe/fpepanel.htm
the selling RE agent ... was not to happy with the outcome. How do I know this just from the tone of her voice I have been sleeping with her for almost 43 years yes all is disclosed up front and on the table
Wouldn't fly here in NY ... You cant do an inspection where a relative or business partner has a financial interest. Period ... no disclosure provision for that.
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
Old 6/12/11, 9:46 AM
Joseph Hagarty,  CMI's Avatar
Additionally, how much do you Charge for these type of extended scope inspections?
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 6/12/11, 10:04 AM
James F. McKee's Avatar
so Charley has been sleeping with the enemy.....
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
More Signs of the Times: At foreclosure auctions, broken dreams on sale jburkeson1 Miscellaneous Discussion for Inspectors 0 10/15/09 11:36 AM
How to Cope With Hard Economic Times mcyr Miscellaneous Discussion for Inspectors 6 8/7/09 8:39 AM
Surviving Bad Times mcyr Miscellaneous Discussion for Inspectors 13 1/10/09 11:19 AM
