Old 3/19/07, 10:26 AM
Michael J. Ashburn's Avatar
Michael J. Ashburn Michael J. Ashburn is offline
Default Tinned copper wiring
Does anyone have any photos of what exactly "tinned copper" wiring looks like, or its general characteristics.
Any Help would be appreciated.
Thank you.
Ashburn Inspections
724-516-1665
Old 3/19/07, 10:39 AM
Paul W. Abernathy's Avatar
Default Re: Tinned copper wiring
Check out the image....older tinned copper has these traits
1.) Look at the tips of the wire as they enter into the buss bar...the ends are copper dots within the shiny portion.
2.) The tinned outter shell tends to remain shiny versus aluminum
3.) The outer jacket tends to be rubberish and frattered on the ends in most cases.
Hope these help
Paul W. Abernathy,CMI,CPI,CME
Old 3/19/07, 12:46 PM
David C. Macy's Avatar
David C. Macy David C. Macy is online now
Paul
Would you have any pictures of copper clad aluminum wiring?
Old 3/19/07, 1:00 PM
cbuell's Avatar
cbuell cbuell is offline
Please Note: cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
Here is a picture of some tinned copper where I have scraped off the tin at the end. This was lead jacketed underground wire. From left to right: Lead jacket, rubber covering, zinc coated copper and cleaned copper.
Old 3/19/07, 1:02 PM
David,
I don't right off....but I will find one for you...but here are some interesting things about it you may find helpful:
Copper-clad aluminum wire has a thin copper outer skin and a core of aluminum. Therefore it looks like copper, except on close examination of a cut end. Markings on the cable jacket would include "Al" or "Aluminum". There is no known history of connection overheating problems associated with copper-clad aluminum wire. No corrective actions are required for copper-clad aluminum wire.
MIS-IDENTIFICATION - PLATED COPPER WIRE as "Aluminum"
Plated copper wire is relatively common in older homes, and it looks like aluminum wire. It was commonly used with rubber-based insulation. Identification can be made by careful inspection of a cut end of the wire. In general, plated copper wire would not be present in nonmetallic sheathed cable ("Romex"), it is most generally found in metallic sheathed cable ("BX"). Cable of the "BX" type is not likely to contain aluminum wire.
Old 3/19/07, 1:06 PM
Sorry I do not have a photo. I could not see the ends at buss bar, way too compact.
The wire that I saw looked like;
2.) The tinned outter shell tends to remain shiny versus aluminum & 3.) The outer jacket tends to be rubberish and frattered on the ends in most cases. It also was FMC.
Paul, Charles, did they used to run tinned copper or aluminium in FMC?
I appreciate your responses!
Thank You All!
Ashburn Inspections
724-516-1665
Old 3/19/07, 1:17 PM
cbuell's Avatar
Paul, the tinned copper is also present in all (or most) knob & tube and "early" un-rounded non-metalic sheathed cable----including the old "snake-skin" with/without ground.
Old 3/19/07, 1:26 PM
thanks...yeah I was kinda speaking to modern day romex so to speak....I find alot of K & T in just plain copper........but then again by the time I find it I am rippin it out...
Top Ten Wiring Hazards jtedesco1 Electrical Inspections 6 9/1/08 9:26 PM
Nice Report on AL Wire Terminations - Enjoy pabernathy Electrical Inspections 0 7/2/07 1:35 PM
Proper Marr Connectors for Aluminum Pigtails jskrypka Canadian Inspectors 4 3/25/07 11:41 PM
Looking for comment by Caoimhín P. Connell phinsperger Ancillary Inspection Services & Additional Topics 2 2/18/06 12:22 PM
