Name the obvious issues, and see if you recognize some of the less obvious issues...
| Need a home inspection in Minnesota? Check out InterNACHI's listing of Minnesota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Zinnsco & aluminum wire.......
and all that comes with it..... Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
Well, that does sum it up nicely
arcing at the breaker connection (pic 3)...
arcing and melting of the wire nut (pic 4)... is that the neutral connection? Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
First picture, appears to be oversized conductors cut to fit the breaker, difficult to be sure
Second picture solid aluminum conductors, excessive conductor exposed #2 and 3 Third picture ZINSCO = Kiss of death, corrosion maybe arcing? Fourth picture excessive heat in wire nut, something is going on there |
The breaker happens to be the 125 service breaker and it has almost completed its "fusion" to the bus bar IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
dmcmullen is a non-member guest and is in no way affiliated with InterNACHI or its members.
Would you call out that the strands on what appears to be the SEC were nicked pretty deep? Or the insulation cut back too far? Were the AL wires loose on the breakers or was the insulation cut that far back on all of them?
Jeff, do you take any thermal images of these to show the heat/connection issues?
BPI Certified Professional Building Analyst BPI Certified Envelope Professional Infraspection Institute Certified Level II Thermographer # 8510 www.dapkusinspections.com www.chicagoinfraredthermalimaging.com www.mychicagohomeinspector.com www.commercialbuildinginspectionchicago.com Professional Infrared Network Chicago Energy Audit Aerial Infrared Inspection Certified Infrared Thermal Imaging |
That would make a nice pic..
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
The only indicators of poor connections (other than the obvious visible indications) were at the grounding conductors. Many of the receptacles measured near 2 ohms of impedance on their egc's. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
I see the aluminum wire.
I see several skinned back to far ????? Questionable. In pic. #3 is there arcing in there back top side of the breaker on the bus. #4 is obvious. Its plain arc fault. Is this a paste problem I read about? montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
even the voltage-drop measurements were unusually low.
Some one point me to doing this testing please. I have read a bit about doing drop testing. Links please. montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
You can start here http://www.idealindustries.com/prodD...?prodId=61-165 then go
here http://www.nachi.org/forum/f19/warra...ections-20969/ |
Thanks Mr.Mallarkey
I'm curious, what do you guys do with the results you get from voltage drop testing?
| Need help with todays inspection | prussell | Inspecting HVAC Systems | 4 | 1/29/07 10:28 PM |
| Pro-Lab and Dr. Shane at Today's Inspection | mkyriacou | IAC2 Indoor Air Forum | 16 | 11/13/06 10:29 PM |
| Todays subpanel | sstanczyk | Electrical Inspections | 5 | 2/8/06 11:05 PM |
