Old 2/1/11, 10:55 AM
Russell J. Hensel's Avatar
Russell J. Hensel Russell J. Hensel is offline
Default Too bad ALL inspectors don't pull the panel covers
Here is ANOTHER defect that would not have been noticed if the panel cover was not pulled. So what happens to buyers who have inspectors who do not pull the covers off? Just curious.
Imagine this not getting noticed. It was 312 degrees MAJOR FIRE HAZARD...
Comprehensive Building Consultants
Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection.
Donate here:
or send checks to the
Fl Home and Insurance Inspector Chapter
1103 W Hibiscus Blvd Ste 311
Melbourne, Fl 32901
Need a home inspection in Montana? Check out InterNACHI's listing of Montana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/1/11, 11:13 AM
John Harrison's Avatar
John Harrison John Harrison is offline
Default Re: Too bad ALL inspectors don't pull the panel covers
I pull every panel, unfortunately there is the occasional panel that I once pulled I wish I had left alone.
Performing Home Inspections in Council Bluffs, Missouri Valley, Glenwood, and surrounding areas
Active Rain Member
Old 2/1/11, 11:21 AM
Michael Larson's Avatar
Attachment 41739
Maybe you could explain a "312 degrees major fire hazard".
Remember we are all here to learn.
Michael Larson
Hudson, WI
Old 2/1/11, 11:30 AM
Timothy R. Wendorff Timothy R. Wendorff is offline
Who doesn't pull off the cover?? I pull every cover (except one about 4 months ago that had water dripping from it! It had a leaking bathtub above it.)
Old 2/1/11, 11:32 AM
What I am saying is that the phase A wire had a 312 degree temperature while phase B had a 81 degree temperature and the power was balanced with about the same number on each side and the same amount operating. When a phase is this significantly different from the other with a balanced load this is a fire hazard. Unless the outer sheathing on the wire is intended to melt under normal conditions...
Donate here:
Melbourne, Fl 32901
Old 2/1/11, 11:33 AM
You would be amazed at the number who dio not pull the covers....Sad but true.
Donate here:
Melbourne, Fl 32901
Old 2/1/11, 11:35 AM
rsmith24 rsmith24 is offline
You would be amazed at the number who do not pull the covers....Sad but true.
Probably the same amount that don't get on the roof.
INSPECTIONLOGOS.COM
"I can keep explaining it for you, but I can't understand it for you".
Nick G.
Monroe Home Inspection
Old 2/1/11, 11:37 AM
Thank you.
Michael Larson
Hudson, WI
Old 2/1/11, 12:19 PM
Banned
Just about missed one like that a few years back.....I wish I would have had your inspection team that day...the house took 7.5 straight hrs not including driving and report writing!!
The house had a main and 2 remote subpanels. At the end of the inspection, I still hadn't done the 2nd remote subpanel as it was in a location with poor access (that was remarked on also) due to furniture! I actually considered not removing the panel since the other elctrical in the house was very good....but I persevered, moved the furniture and opened it to find........a red feeder wire charred black for about 2.5" from the terminal!! ............a lesson learned!!
Old 2/1/11, 12:32 PM
James L. Keilson's Avatar
James L. Keilson James L. Keilson is offline
Send a message via ICQ to jkeilson
Attachment 41739
AHHHH nice find bro. As an electrical contractor since 1986 I have seen all kinds of electrical safety issues. This one is right there with the best of them as this is a serious fire just waiting to happen. In reality the rest of the home could be 100% perfect with Zero deficiencies, you send your report, the new buyer is at closing, they finish closing, get their new keys, drive over to see there new house, pull up the street, and BAMM>>>> fire department just packing up with a smoldering pile of rubble and ash behind them...
Jim
Maryland Home Inspection Services Inc.
www.MarylandHomeInspectionServices.com
State of Maryland License# 31141
Virginia License#3380 000468
National Association Of Certified Home Inspectors ID: NACHI10101807
International Association of Certified Indoor Air Consultants (IAC2). Certification # IAC2-02-0919
Maryland Home Inspectors In Gaithersburg, Rockville, Germantown, Bethesda, Potomac, Also All of Northern Virginia and Washington, D.C.
Old 2/1/11, 12:33 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
Inspectors should not open two types of Panels. They don't open them because of the danger. Even a seasoned electrician will not open the panels unless they can shut the power off. If we are not allowed to shut the power off the best thing is to refer to a certified electrician. No client of mine that has seen me do an inspection would appreciate the breakers falling out of the clip in design. I have even seen them pushing out the dead front. Are you saying you would open this kind of panel?
Not wise.
Take some pictures of the panel and call the ESA.If you are to pull a Panel that is defective you may be doing a replacement of the whole panel.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
ESA and MOL Inspectors Conversation Opening Panel Covers jbettencourt Canadian Inspectors 7 5/6/09 10:23 PM
Asbestos Inspectors in Coeur d’Alene, ID 83815 rspriggs Ancillary Inspection Services & Additional Topics 0 1/9/09 3:25 AM
BC is acting on the new bill jkoong Canadian Inspectors 21 2/19/08 7:38 AM
