Old 12/6/08, 3:41 PM
Kenneth R. Malone Kenneth R. Malone is offline
Default Twisted ground wires in main panel
Several ground wires are twisted together and inserted under one lug in the main panel. Should I write this up different than just a double tap?
Old 12/6/08, 4:58 PM
mnahrgang's Avatar
Default Re: Twisted ground wires in main panel
ground wires can share a lug.
Mark Nahrgang
www.HeyMark.info
Old 12/6/08, 5:49 PM
Unmoderated Guest
Typically up to three of the same size. Sometimes different sizes are OK.
What is shown is likely not compliant, but is not dangerous either.
Old 12/6/08, 6:04 PM
Marc D. Shunk's Avatar
Banned
I agree. I wouldn't really do it that way, and while it's a technically a code violation, I can't really see that as being anything worth getting cranked up about. If I was giving advice to a home inspector about that, I might advise him to simply document that the condition exists, and refrain from further comment.
Old 12/6/08, 6:11 PM
jkogel jkogel is offline
I called for an electrician to repair the twisted grounds in this panel on Wednesday. No lug whatsoever.
At least they've kept the Al separate from the Cu here.
Corrosion, multiple double-taps, missing branch ground screw, solid Al, all in an FPE panel.
John Kogel
www.allsafehome.ca
twisted-ground-wires-main-panel-twistedgrnd.jpg   twisted-ground-wires-main-panel-lostscrew.jpg
Old 12/6/08, 8:01 PM
Bruce A. King's Avatar
Based on FPE information available to home inspectors that panel should not have had any repair recomendations. Replacement would have been the proper call.
www.BAKingHomeInspections.com
704 301-3207
Old 12/6/08, 8:20 PM
Probably right for your area, Bruce.
This is Canada, we're different up here.
Federal Pioneer panels are being installed in new houses every day.
http://www.schneider-electric.ca/www...ok/html/cb.htm
Hopefully the electrician will determine the condition of the breakers and the panel.
Old 12/7/08, 12:52 AM
I wrote it up as not being the prefered method. I did not list it as a safety issue or a repair. Thanks, for the info.
Old 12/8/08, 11:24 AM
If I could determine that all the wires twisted together were actually terminated under the screw, I would not write it up because, twisted or not, more than one ground wire per screw is allowed. On the other hand I once saw a panel that had virtually ALL of the grounds twisted together into one big mess with only one or two strands actually terminated. That's a different story, IMHO.
Frank P. Newman
Emerald City Inspections, LLC
Dublin, GA
Old 12/8/08, 11:43 AM
Banned
True, but not 4 or 5, like pictured. Functionally, you and I both know it will work fine. I think those ground bars are only rated for up to 2 per hole. Some are rated for 3.
Old 12/8/08, 9:06 PM
You are correct, of course; however, whenever, I find such a panel there is usually more about which to be concerned.
Frank P. Newman
Dublin, GA
new ground bar kit Mike Kasper Electrical Inspections 12 12/1/08 11:12 PM
Need help with main panel board buss bar smcintire Electrical Inspections 63 1/8/08 6:55 PM
Panel Inspection Safety roconnor Electrical Inspections 10 9/24/06 10:02 PM
Sub panel main tripping? crichiii Electrical Inspections 6 9/19/06 11:08 PM
Bad electrical problem Pest Guy Electrical Inspections 4 1/20/06 10:26 PM
