Old 11/5/06, 8:26 PM
Bill Smith's Avatar
Bill Smith Bill Smith is offline
Default Two circuits in one cable
This mornings inspection had some interesting features courtesy of Home Depot Harry. A 12/3 w/ground was found in the service panel. One wire (and the grounding conductor) landed on the neutral bus, one on a 30-amp breaker (for the dryer) and one on a 15-amp breaker for the lights in another room). I know that the 12awg wire being on a 30-amp breaker is wrong and I suspect the shared circuits in the cable is wrong but can't find the proper wording for that. Any thoughts?
http://www.SmithHomeInspection.com
SmithHomeInspection@yahoo.com
NY State Lic. # 16000008304
631-434-5200
Old 11/5/06, 8:47 PM
Jason A. Sieg, CMI's Avatar
Jason A. Sieg, CMI Jason A. Sieg, CMI is offline
Default Re: Two circuits in one cable
How did he get 220v off of one wire. I'm sure that there are 110v dryers out there, but most require a 220v breaker, a 220v receptacle and of course at least 10 gage wire depending on distance of the circuit.
Dryer circuit improperly wired. This could be a fire hazard.
(Brown outing equipment can cause fores too!!)
Dryer circuit - Electrical wire size appears to be under sized on circuits that routinely carry heavy loads. This is a safety and fire hazard.
Non-conventional electrical wiring of multipal circuits. This may cause electrical hazards and/or fire. This may also be an electrical code violation. Your Home Inspector is not a Code Inspector an strongly suggests that the electrical system be inspected by a qualified, licensed, electrical contractor.
The third one I thinks looks the best, but may need some tweeking.
Jason Sieg, CMI
Davison, MI
NACHI05091399
Knowing the current condition,
to make a wise decision.
President, Great Lakes-East Chapter
Join NACHI Great Lakes - East Chapter
http://mi.nachi.org/greatlakes-east/about.html
ssieg@gfn.org
Old 11/5/06, 8:49 PM
Unmoderated Guest
This is called a "multi-wire" circuit and is perfectly normal. Provided it is wired properly.
"Properly" would be, obviously, breaker sized according to wire size, and the two breakers being on different legs of the panel. Better yet, in a typical panel right next to each other. Many will suggest a two-pole, or handle-tied breaker.
**Edit - On re-reading, I assumed a gas 120v dryer. If this is a 120/240v electric dryer all bets are off.
Old 11/5/06, 8:56 PM
You know what, I thought electric dryer when I read it was on a 30 amp breaker. But after reading your post, who knows if it is a gas dryer or electric?
Jason Sieg, CMI
Davison, MI
NACHI05091399
ssieg@gfn.org
Old 11/5/06, 10:32 PM
Bill Smith's Avatar
It was a gas dryer. Only one side of the double breaker was used for that (improperly).
My question really was about the two different circuits being fed by different conductors in a common cable. Shouldn't dedicated lines have been run for each circuit?
631-434-5200
Old 11/5/06, 10:49 PM
Unmoderated Guest
Absoultely not. A multi-wire circuit is perfectly fine, if wire right.
Old 11/5/06, 10:52 PM
No. It is a common and efficient wiring method. If you think about it, it's the same as the power coming into the house from the transformer. It is also done this way in conduit most of the time to decrease conductor count for pipe fill.
Old 11/5/06, 10:54 PM
Bill Smith's Avatar
Interesting. I know multi-wire circuits for the same circuit (240-volt dryer, etc) are fine, but the differrent circuit thing threw me. Thanks Pete. Thnaks Brian.
631-434-5200
Old 11/5/06, 11:06 PM
Unmoderated Guest
In the case of a dryer for instance, it is not considered a multi-wire circuit.
That is simply a 120/240v circuit.
It really is kind of odd. A dryer is not considered a multi-wire, and the circuit terminates on a single device yoke.
Yet a multi-wire circuit, terminating only on a split duplex receptacle IS still a multi-wire.
Old 11/5/06, 11:34 PM
Bill Smith's Avatar
Thanks again Pete.
631-434-5200
Old 11/6/06, 9:19 AM
Paul W. Abernathy's Avatar
Bill,
yes, multi-wire circuits are fine if done correctly. It is also a good example of why you want the netural terminating on the neutral buss correctly when it comes to a multi-wire circuit....remove that neutral on the circuit and well.....you burn up equipment and a hazard is produced....
So people should not do multi-wire circuits unless they truly understand what is going on with them......and one important note is to ensure the multi-wire circuit has each circuit on a different leg in the panel.....lke peter said side by side on the same side ensures that.........if split up in the panel YOU run the risk of it being wrong and a neutral conductor that could be overloaded........very important to know how they work....
Paul W. Abernathy,CMI,CPI,CME
Short circuit failures with 12/3 NM-B cable and NM clamp connectors pabernathy Electrical Inspections 10 4/17/11 2:43 PM
Did you KNOW this about NM Cable? pabernathy Electrical Inspections 0 12/19/06 9:46 AM
Hey Joe Tedesco pbolliger Electrical Inspections 7 4/11/06 1:17 AM
Ceilings falling with wires in it. jsmith3 Interior Inspections 8 3/16/06 8:24 PM
