Old 4/6/07, 4:43 PM
Default Two Prong Outlets
I've only been inspecting a short while and today I did my first house with two prong outlets.
This is probably a dumb question but, what do you do? My three prong tester wouldn't go into the three prong outlets. How do I know they were even working?
Old 4/6/07, 4:53 PM
Michael Larson's Avatar
Default Re: Two Prong Outlets
May I suggest a cheater plug or a test light?
Old 4/6/07, 4:59 PM
rromoser's Avatar
rromoser rromoser is offline
Pick up one of the grounding adapters for a dollar. Just verify that is a polarized one. (The hot prong will be smaller than the neutral prong) The tester you are probably using should only show an open ground when using the 3 prong adapter. That will indicate correct polarity.
Old 4/6/07, 8:45 PM
Yuri Olhovsky's Avatar
Yuri Olhovsky Yuri Olhovsky is offline
John, you can check if the receptacle is operable by using volt stick or voltmeter. Regardless, since two prone receptacles are ungrounded you should recommend upgrade to grounded ones (at least those that will be used for computers) or GFCIs as a bare minimum.
Yuri Olhovsky CMI, CEA, PHPI, RASDT
National Home Inspector NHICC #00372
Richmond Hill, ON Canada
NACHI ID 04070207
www.homeinspections4u.biz
Old 4/7/07, 6:53 PM
Plain ole' Ticker will work....you can verify it is working, you can determine if it has proper polarity and it will only cost you about $ 15.00-$20.00 bucks.
Paul W. Abernathy
Old 4/7/07, 8:24 PM
Marc D. Shunk's Avatar
Banned
That'll let you know if it's got a hot wire, but it won't let you know if the rec is functional (open neutral). I'd rather test for polarity with a TIC tracer and plug a test lamp in to verify functionality, if a functional test is what is intended.
Old 4/7/07, 9:33 PM
If it is an old receptacle, predating the 3 prongers both holes will probably be the same size so how will you determine polarity? It may just be installed upside down
Old 4/7/07, 10:03 PM
Bruce A. King's Avatar
Don't forget to note the ones that have lost their tension. Most will be bad in an older home to the point of plugs falling out easily.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 4/7/07, 11:44 PM
Joe Farsetta's Avatar
Joe Farsetta Joe Farsetta is offline
ESOP Committee Member
Correct me if I am incorrect, but Yuri's statement regarding a 2 prong being ungrounded is innacurate.
If the system is grounded, and the ground is extended to the box, and the receptacle is mechanically bonded to the box, then the receptacle is "grounded", no?
My thoughts are that the difference between a 2 and 3 prong is that they are both technically grounded, but the 3-prong allows the system ground to extend to the applicance it connects to, if a ground plug is required.
Cheater plugs should have the green wirre, or green metallic thingie, securely fastened via center screw on the receptacle cover, otherwise using them is a no no.
So, assuming the system is indeed "grounded", am I right or wrong here?
Old 4/8/07, 12:01 AM
Joseph Hagarty,  CMI's Avatar
Originally Posted by jfarsetta
Correct me if I am incorrect, ...
....am I right or wrong here?
I will disagree merely to draw a response as my curiosity runs concurrent with yours.
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 4/8/07, 12:02 AM
Joe, old houses that have two prong receptacles most likely were wired with old cloth-covered wiring that did not contain ground wire. How could the outlets be grounded?
NACHI ID 04070207
Old 4/8/07, 12:04 AM
Yuri,
1930-40 Homes wired with BX are quite common.
Joseph P. Hagarty
Phone: 610-399-3675
Old 4/8/07, 12:08 AM
Joe, I agree with BX, but this is expensive and was not so common here. Anyway, two prong receptacles are outdated to comply with "modern days requirements"
NACHI ID 04070207
Old 4/8/07, 12:15 AM
Geographic differences noted.
While BX may not have been commonplace in your area, BX was quite common in this area.
Joseph P. Hagarty
Phone: 610-399-3675
Old 4/8/07, 1:30 AM
Yuri,
If the receptacle is not damaged, and the system is indeed grounded (easy to determine when the dead front cover is removed), and the 2-prong is grounded, then what is the problem? Is the receptacle defective, or not?
Also, what does "outdated by today's requirements" mean? I submit that a majority of today's plug-in electrical devices do not require a system ground (except for vacuums, cleaning machines, some other motor-driven appliances, etc). Some double-wound electric motors no longer require it, either. I'm not poo-pooing the idea, by the way. I'm going back to the initial question and Yuri's statement.
As to any assumption whether a ground conductor is present in the branch distribution cable, this is the reason the dead front cover is removed. As I stated, we'll assume that the distribution system is grounded. That was what my comment was directed at. There are some clowns who take a cable, absent of grond conductor, and bootleg the neutral. Just because it has a "grounding" receptacle doesnt mean it's correctly wired.
Now, (again) the original question went to testing. If you have a cheater plug (which is not a way to cheat, really, but a way to extend the system ground to a device that requires it), then a wiring tester is adequate. I touch the green wite to the center screw on the receptacle cover...
I'll bet that some of these original systems and receptacles are sometimes safer then when Harry The Homeowner strikes.
Properly Testing GFCI Outlets tchristopher Electrical Inspections 17 3/17/07 11:19 AM
2 prong and 3 prong? gbrasseur Electrical Inspections 4 3/2/07 4:50 PM
Two Prong Outlets sboyd2 Electrical Inspections 79 9/4/06 7:05 PM
Two prong outlets and GFCI's crichiii Electrical Inspections 8 3/15/06 10:41 PM
