Old 11/27/07, 1:17 PM
rtrain's Avatar
rtrain rtrain is offline
Default Two Quick Questions On Receptacles
I have two quick electrical questions. On the first picture, what are the spacing requirements for receptacles at counter top level? On the second picture; should these receptacles be GFCI protected? They are in a laundry room, but not on a counter top with the sink. It is a galley style laundry room with the laundry sink on one side and work space on the other.
Thanks
Russell Train
two-quick-questions-receptacles-img_0024b.jpg   two-quick-questions-receptacles-img_0016jh.jpg
Old 11/27/07, 1:27 PM
Jim Port Jim Port is offline
Unmoderated Guest
Default Re: Two Quick Questions On Receptacles
If this were a kitchen a new install would require that no wall space was more than 2' from a receptacle, ie 4' spacing. Also any countertop 12" wide or more would require a receptacle. There are other rules regarding islands and penisulas.
A new laundry room would require GFI protection for receptacles within 6' of the laundry tub. It would also require a circuit dedicated to just the laundry room receptacles. This would include the receptacle for the washer if within the 6'.
What year was the house built? Is this a kitchen or a wet bar?
Old 11/27/07, 1:33 PM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
Here is a quick link from 2005 NEC on that area.
http://www.ul.com/regulators/ode/0105.pdf
Old 11/27/07, 1:36 PM
rtrain's Avatar
Its new construction and it's a wet bar.
Old 11/27/07, 1:56 PM
rtrain's Avatar
Ok. So what I can gather is… on the counter top of the wet bar you would only need one receptacle, because it’s not a food prep. area , but the counter top is more the 12” wide so it requires at least one receptacle (the outlet shown is GFCI protected). For the laundry room those receptacles would need GFCI protection because they are within 6 feet of the washer (even though the washer is front loading and under the counter top)? Thanks for your help guys.
Russell
Old 11/27/07, 4:36 PM
The laundry does NOT need to be GFCI. The 2005 rule is 6' from the sink, not the washer.
Old 11/28/07, 12:10 AM
rtrain's Avatar
Thanks Greg
Old 11/28/07, 12:24 AM
mthomas2 mthomas2 is offline
See below:
Receptacles not having acceptable blade retention jtedesco1 Electrical Inspections 12 1/28/12 9:40 AM
AFCI Questions and Answers - Mike Holt pabernathy Electrical Inspections 2 1/8/11 8:04 PM
open ground on 3 garage receptacles dnasser Electrical Inspections 14 10/30/06 6:53 PM
Some good questions that always need answers jtedesco1 Electrical Inspections 5 6/16/06 10:10 PM
