Old 11/5/06, 11:24 PM
cbuell's Avatar
cbuell cbuell is offline
Please Note: cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Two services
Has anyone out there ever encountered, or heard of, two distinct services to the same property (both services derive from different transformers)? One service enters the back of the house from the alley while the other is to the front of the house on the street side. All of the bonding/grounding of both systems utilize the same plumbing system----no ground rods for either system. One is a 60 amp service dating to the 30's, while the other is a 100 amp service dating to the 60's.
Old 11/5/06, 11:27 PM
Roy D. Cooke, Sr's Avatar
Default Re: Two services
Yes usually to two apartments . If it is a single home now they should go to a single service much cheaper here in Canada.
Roy Cooke
Old 11/5/06, 11:33 PM
cbuell's Avatar
To clarify both of these services go to the same house on the property.
Jeffrey R. Pope's Avatar
Hmmm.
230.2 Number of Services.
A building or other structure served shall be supplied by only one service unless permitted in 230.2(A) through (D).
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 11/5/06, 11:34 PM
Unmoderated Guest
No way. That should have never been allowed to happen. At least in any place that had any codes in place.
Multiple services are common, but are connected to a single drop or lateral. This is common as Roy stated, for apartments and multi-family's.
Unless there is a firewall, creating two "sepatate" parts of the same structure; then two distinct services, fed from different sources, in different locations on the structure, is not legal now and I would think it never was.
Old 11/5/06, 11:55 PM
Dennis Hodkinson Dennis Hodkinson is offline
Please Note: Dennis Hodkinson is a non-member guest and is in no way affiliated with InterNACHI or its members.
It could be that the building was converted to a duplex to rent out a portion of the house back in the 60's and years later a new owner came along and converted it back to a single family dwelling.
Old 11/6/06, 12:42 AM
cbuell's Avatar
The home is listed as a "legal" duplex but it is actually more like a mother-in-law as there is free communication between the upper and lower unit without firewall/fire-door separation. And as stated earlier both systems appear to share grounding/bonding.
Old 11/6/06, 10:38 AM
Here are some of the exceptions that may or may not apply. . .
(B) Special Occupancies.
By special permission, additional services shall be permitted for the following:
(1) Multiple-occupancy buildings where there is no available space for service equipment accessible to all occupants, or
(2) A single building or other structure sufficiently large to make two or more services necessary
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 11/6/06, 3:37 PM
If it is permitted as a duplex there is no problem with 2 services. Around here that may actually make the house more valuable since they limit duplex zoning now and you can't split a single family home.
Old 11/6/06, 5:54 PM
cbuell's Avatar
Greg, is there no problem with the mixing of grounding/bonding?
Old 11/6/06, 9:10 PM
I can't see a problem with sharing the ground electrode system. You would not want to see any regrounding or combining of the neutral after the service disconnects tho.
In an old area with all metal plumbing the whole city shares a grounding electrode system.
Old 11/6/06, 10:21 PM
cbuell's Avatar
Thanks Greg
Old 11/6/06, 10:34 PM
How many main panels and separate sevices might you expect to see in a 25.000 square foot home? Commercial kitchen... toys pulling lots of power, etc. Maybe three 200 amp services?
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 11/6/06, 11:16 PM
I did a 20K sq ft that had a single, 1600 amp - three phase service. . .
Commercial kitchen, two elevators and a vehicle lift (4 vehicle capacity).
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 11/7/06, 1:30 AM
Jeff, I am curious what you charged for that inspection?
