Old 12/31/06, 7:13 PM
mthomas2 mthomas2 is offline
Default Is this type of elbow OK for "buried" use?
Rigid conduit from meter to service disconnect.
Is this pull elbow OK for "buried" use?
If not, code cite of possible, please.
Thanks.
type-elbow-ok-buried-use-elect-conda.jpg   type-elbow-ok-buried-use-elect-condb.jpg
Old 12/31/06, 7:24 PM
rromoser's Avatar
rromoser rromoser is offline
Default Re: Is this type of elbow OK for "buried" use?
It looks like an aluminum "LB" as opposed to being a malleble iron type. I wouldn't want either one underground. The aluminum one will corrode very quickly in this application. NEC 300.6 Raceways, cable trays....fittings... shall be of materials suitable for the environment in which they are installed.
Here's the other side of the meter, BTW:
type-elbow-ok-buried-use-elect-serviceconduitc.jpg   type-elbow-ok-buried-use-electserviceconduita.jpg
Old 12/31/06, 7:25 PM
Marc D. Shunk's Avatar
Banned
That is called an LB fitting. Buried is not the trouble. The fact that the cover is not accessible is trouble.
NEC 314.29 Boxes, Conduit Bodies, and Handhole Enclosures
to Be Accessible.
Boxes, conduit bodies, and handhole enclosures shall be installed so that the wiring contained in them can be rendered accessible without removing any part of the building or, in underground circuits, without excavating sidewalks, paving, earth, or other substance that is to be used to establish the finished grade.
rromoser's Avatar
I attended Oakton School in Evanston 40 yrs. ago. Is it still there?
Old 12/31/06, 7:31 PM
rromoser's Avatar
Won't it be accessible when the fitting completely corrodes away in the next couple of years?
Old 12/31/06, 7:40 PM
Banned
. http://database.ul.com/cgi-bin/XYV/t...693&sequence=1
Old 12/31/06, 7:45 PM
rromoser's Avatar
Isn't it prone to galvanic action with the soil which would be different than just being in a wet environment?
Ted Allen Ted Allen is offline
Mr. Shunk it looks like you will be an asset to our little community.
Welcome to the show.
Old 12/31/06, 7:48 PM
rromoser's Avatar
If it is okay to bury the LB, how can it ever be accessible?
Old 12/31/06, 7:50 PM
Banned
If it was pointed downwards, cover facing up (for instance).
Even if burial has some deleterious effect on the LB (a topic on which there is some doubt), it is much easier to cite the more direct violation of the cover not being accessible. Either reason might make the installation "wrong". One reason just has more clear text on the matter.
Old 12/31/06, 7:52 PM
But we only do that when we are running a conduit to CHINA.....
Paul W. Abernathy
Old 12/31/06, 7:57 PM
As far as I can remember it is not OK to bury a JB wether it be an LB, LR or a 4 square. I seem to remember that they all must be accesible to qualified personel. I would look it up, but I dont want to.
Old 12/31/06, 8:01 PM
Hmmm, me smells a Joe Tedescoe. lol
It's cool Joe you do not need to post under a different name.
Old 12/31/06, 8:12 PM
I take it back Mark.
I was just informed that you are NOT Joe Tedescoe, but a close cousin. lol
However, I would like to check.
Here you go.
The primary of a transformer draws 4 amps at 7,200 volts.A reading at the secondary shows 110 amps at 240 volts. What is the efficiantcy of the transformer at this load?
Fire rating abolt Structural Inspections 13 9/21/07 8:45 PM
Surface type panel box abolt Electrical Inspections 2 9/4/07 10:44 PM
Roof type & excessive leaking dmacy Exterior Inspections 7 9/12/06 12:07 PM
Massachusetts Board of Registration of Home Inspectors jtedesco1 Legislation, Licensing & Legal Issues for Inspectors 0 2/14/06 3:38 AM
