What of fasteners should be used to secure the service panel to the wall? Surely, not drywall screws.
Thanks! |
Surely not.
Michael Thellend is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hi,
Usually #8 or 10 X 1" pan head wood screws. If you use #8 screws you may need washers, I always use washers anyway. PS: Depending on type of backing and wall you have, you can use the aforementioned. I wouldn't use anything less than a 3/4 screw for a small panel. If you have concrete behind a piece of 1/2 wood you could trace your panel holes and use a hammer drill and install plastic anchors without removing the wood. Then use some 1' 1/2 to 1' 3/4 pan head wood screws. Last edited by Michael Thellend; 2/11/09 at 6:24 AM.. |
Thanks!!!!
| Electric Panel | dmozzillo | Electrical Inspections | 26 | 1/26/09 1:18 PM |
| Commercial Electrical Inspections | jtedesco1 | Commercial Inspections | 29 | 1/12/08 5:03 AM |
| Service Panel Quiz? | hmcclard | Electrical Inspections | 5 | 10/24/07 11:53 PM |
| Zinsco Service Disconnect Panel | pdickerson | Electrical Inspections | 7 | 9/16/06 11:59 AM |
