gmathias is a non-member guest and is in no way affiliated with InterNACHI or its members.
An unusually high number of homes that I have seen over the last month or so have a grounding electrode that exits the foundation and enters the earth. No stake...No anything. I don't know if this is a part of a Ufer ground or some other system that I can not determine. I indicate "unable to confirm proper grounding" on my reports, but I wish I could provide a better statement. Any suggestions
smcarthur is a non-member guest and is in no way affiliated with InterNACHI or its members.
The photo is kinda small, but that looks like a regular 8' driven ground rod. Or is it rebar from the foundation? Hard to tell from the photo.
The rod may be driven below grade. That is OK
Sorry about the size of the pic. There is a 4 awg copper wire going into the earth. Yes, it's probably attached to a rod somewhere, but I dug down about 6 to 8 inches and didn't find a rod.
That looks like a water pipe clamp. If so, to what is it attached?
The wire enters the earth, no clamp, no stake.
Are you able to find the other end of it into the ground....some mistake the # 4 in 20' lengths as a proper grounding method.....while it would be in the foundation of concrete....not in the ground itself.
So I would say what you have listed on your reports based on the lack of information is about all you can put at this time. Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
Not Inspected / (followed by a description of the limitation)
Joseph P. Hagarty, CMI joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
I have found on more than one occasion, the conductor going into the soil without any kind of rod or clamp, Period. Also routinely find the "water pipe" clamp is completely disentagrated or only small pieces left, or extremely corroded because the "Weaver" clamp is not made for burial or wet enviroment.
What do you report when you see the ground wire entering the ground? Do you recommend evaluation by an electrician?
Since the ground rod is driven before the landscaping is completed, it may be that the ground rod was buried below the finished grade by several feet of soil.
I tug real hard on the conductor. If it can't be pulled up, I assume it's attached to a buried ground rod.
When I can't confirm a ground, I say: "We could not determine the point at which the panel is grounded. Typically, this ground is to a driven ground rod, a water pipe located at the main, at a water heater, or to a hose bib, but we could not find it at any of these locations. Therefore, it should be traced by an electrician or the panel should be regrounded." “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
The connections at a water heater, hose bib, or anywhere other than the water main are simply the water bond. Again, this does not serve to ground anything. I know it is just semantics, and most homeowners have no clue, but it is technically incorrect. |
kind of like "outlet" and "receptacle"
| Electricians Check List | pabernathy | Electrical Inspections | 74 | 12/5/07 7:39 PM |
| Ground Wires Inside a Panel | mveitenhans | Electrical Inspections | 13 | 10/29/06 12:39 PM |
| Electrical Inspection Training for Home Inspectors | jtedesco1 | Inspection Education & Training | 6 | 4/27/06 11:43 PM |
| Harmonized Ground Fault Circuit Interrupters | jtedesco1 | Electrical Inspections | 5 | 3/21/06 9:48 AM |
