Old 8/8/08, 12:37 AM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
Default Underground, is conduit required or .......
In the pic below the wire coming out of the ground is not rated. There is no conduit and it enters the box without cable clamp. Is it necessary to have conduit run the entire way or is UF wire sufficient. This goes partly under asphalt lot.
Thanks
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Old 8/8/08, 12:40 AM
Jeffrey R. Pope's Avatar
Default Re: Underground, is conduit required or .......
UF does not require conduit, except for protection as it exits the ground.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 8/8/08, 12:55 AM
Jeff is that the case even if it runs under parking lot?
Thanks.
Jack Gilleland
jgilleland1@att.net
linkedIn
activerain
Old 8/8/08, 1:18 AM
Here is the reference. . .
300.5 Underground Installations.
(D) Protection from Damage.
Direct-buried conductors and cables shall be protected from damage in accordance with (1) through (5).
(1) Emerging from Grade.
Direct-buried conductors and enclosures emerging from grade shall be protected by enclosures or raceways extending from the minimum cover distance required by 300.5(A) below grade to a point at least 2.5 m (8 ft) above finished grade. In no case shall the protection be required to exceed 450 mm (18 in.) below finished grade.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 8/8/08, 1:24 AM
If it's under a "building," it must be in a raceway or conduit.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 8/8/08, 1:31 AM
Dale Duffy's Avatar
Attachment 23196
Thanks
Jack
You still doing that Pizza joint inspection report?----------
Old 8/8/08, 2:10 AM
They called me and asked if I knew what was needed to move the sign. Seems the road is scheduled to be widened. I referred them to an electrician and then got curious.
Jack Gilleland
jgilleland1@att.net
linkedIn
activerain
Old 8/8/08, 2:28 AM
Dale Duffy's Avatar
I'm busting your balls---
New Washington Legislation Submitted gdomagala Legislation, Licensing & Legal Issues for Inspectors 293 2/10/08 2:20 AM
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 6:58 PM
Emergency Lighting (commercial) mcyr Electrical Inspections 24 6/10/06 11:06 AM
