I have read in an inspection report (from someones website) that the fix can "be as simple as filling the ground slot with epoxy". Is this really a safe fix to do? I would not recommend this.
David InterNACHI #08051301 NYS Lic. #16000038229 NYS DEC Cert # T4865884 518-505-8305 HouseAbout Home Inspections HouseAbout on Facebook NY Capital Region Chapter InterNACHI |
| Need a home inspection in Connecticut? Check out InterNACHI's listing of Connecticut certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Seems strange but there would be nothing unsafe about it.
Please post a link to that report. That sounds like a good read.
I'll have to go and try to find it. He does also state that a ground wire can also be run to the plug and also a gfci can be used. Seams like an amateur fix. I mean if you saw epoxy stuffed in a ground plug during an inspection wouldn't you call for it to be replaced?
Sounds unsafe and that method is not supported by the NEC.
Would it not be simpler to mark it Not a grounded outlet? or replace it with the right outlet.
The accept GFCI outlet on a renovation Permit for non grounded outlets. Wayne Wilson East TN Home Inspections LLC Knoxville, Oak Ridge, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-1490 http://site.myhomeinspection.net |
Prescribing fixes like this is not a good idea.
It may be just a sample report with some verbiage from the manufacturer/software co. If you're gonna tell people to put a liquid form of anything in an outlet I haven't seen and doubt that this is a listed fix from any manufacturer. Home Inspections in Palmdale Lancaster California Tim Spargo Spec Rite Inspections Commercial and Residential Inspections Palmdale Lancaster Santa Clarita CA 661-317-5770 Last edited by tspargo; 12/12/10 at 1:16 PM.. Reason: typo |
"Ungrounded 3-prong outlets ( I.E. near kitchen stove) should be improved. This can be as simple as filling the ground slot with epoxy. Alternatively, a grounded cable could be strung to this outlet, or a separate ground wire could be connected. Some electrical codes allow the installation of a ground fault circuit interrupter (GFCI) type outlet where grounding is not provided." I say his statement is ill advised and borders on incompetent. ASHI inspector I see. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com Last edited by jfunderburk; 12/12/10 at 2:08 PM.. |
Here's what I would have said:
"One or more outlets in the *LOCATION(rooms-interior)* has an open ground. The absence of a ground is a shock or electrocution hazard in some instances and should be serviced by a licensed and competent electrician within the contingency period or before the close of escrow." If the house is an older 2-wire system with 3 prong outlets, I might say this: "Many outlets were the 3-prong type and nearly all were ungrounded. Although a ground isn't required of 2-prong outlets, if the receptacle is 3 prong and ungrounded it gives a false sense of safety. Grounding of all 3-prong outlets, reverting back to 2-prong outlets, or protecting them with ground fault circuit interrupters (GFCIs) is recommended for safety reasons." “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Not unsafe? Squirting liquid into an outlet is safe? How would anyone with a 3-prong appliance use it? Break off the ground pin?
My reply would be similar to what Joe said. But when I took my home inspection class 10 years ago filling the ground with epoxy was one of their recommendations.
Bill Emelander Professional Edge Home Inspection Grand Rapids and all of West Michigan NACHI #03111914 www.proedgehi.com |
Never use an electrical appliance (outlet, receptacle, toaster, etc) in any manner other than as designed by the engineer who designed the toaster, or whatever. I'm not suggesting the use of epoxy--that is a no-no--nor should one label the receptacle as ungrounded--no one reads that, especially if the label is removed. The best thing to do, short of running a proper three-wire, would be to install a GFCI. The GFCI would break the current before harm can be done--hopefully. And use an "ungrounded" label (for as long as it might last). A third wire can, in some instances, be installed--provided it is properly installed. "not just an inspection, but an education" www.homesweethomecincinnati.com Democracy is two wolves and a lamb. Liberty is a well-armed lamb. B. Franklin Last edited by jwilliams4; 12/12/10 at 4:36 PM.. |
| ungrounded outlets | cjustason | Electrical Inspections | 3 | 3/29/10 8:09 PM |
| 2 prong and 3 prong? | gbrasseur | Electrical Inspections | 4 | 3/2/07 4:50 PM |
| Ungrounded plugs | kblair1 | Electrical Inspections | 19 | 12/21/06 8:17 PM |
| Two prong outlets and GFCI's | crichiii | Electrical Inspections | 8 | 3/15/06 10:41 PM |
