Old 10/11/11, 3:33 PM
Jeffrey R. Pope's Avatar
Default Ungrounded Distribution Panel
This was quite a "miss." Not only did the city inspector miss it, this panel had been inspected several times for resale of the property. The current owners were completely unaware of the condition.
The panel is not even equipped with a grounding terminal that would fit the EGC from the service equipment.
ungrounded-distribution-panel-20111011_04.jpg   ungrounded-distribution-panel-20111011_05.jpg
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Need a home inspection in Tennessee? Check out InterNACHI's listing of Tennessee certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/11/11, 5:07 PM
Jeffrey R. Jonas's Avatar
Default Re: Ungrounded Distribution Panel
Awesome... send that to Paul. I'm sure he would get a 'kick' out of it!
Old 10/11/11, 8:10 PM
Robert Meier's Avatar
That's probably the reason why it wasn't terminated, someone would get back to it later.
Old 10/11/11, 8:57 PM
That was my thought as well... I wonder how many more were like that. This was a townhouse community.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 10/11/11, 9:04 PM
Ouch. Could be a big problem. Doesn't say much about all of the inspectors that came along before you. Nice job.
Old 10/11/11, 9:30 PM
Marketing oppourtunity!
Old 10/12/11, 8:55 PM
An HI An HI is offline
Please Note: An HI is a non-member guest and is in no way affiliated with InterNACHI or its members.
Are they not using anti-oxidant paste with aluminum wire in your neck of the woods?
Old 10/12/11, 10:13 PM
Unmoderated Guest
Maybe if they were going to use it they were going to install it when the lug was installed. BTW, there is no requirement for its use, unless called for by the manufacturer. I have never seen a roll of wire with any instructions.
Old 10/12/11, 10:16 PM
I agree, and have heard numerous times that it's required because the conductors are aluminum. I've yet to come across any lug that said you must use it with aluminum conductors.
Old 10/13/11, 8:10 AM
The oxidation that forms on the exterior of bare aluminum is resistant to current flow (while on copper, it is conductive)
http://www.inspectapedia.com/aluminum/alreduce.pdf
See Page 4.
Anti-oxident paste is required on aluminum wire by the AHJ in my area.
Old 10/13/11, 12:40 PM
See Page 4.
Your link didn't work.
This is an old debate. IMO using the paste is a good idea but the notion that it's required is false. A local code would be a different issue altogether. Every terminal that I've seen that was listed for use with aluminum conductors said nothing about the required use of anti-oxidant paste. If I had to guess I would say that as part of the product's listing it's required to be manufactured for use without the anti-ox.
Old 10/13/11, 8:11 PM
Just worked for myself.
Old 10/13/11, 8:35 PM
I tried it just now and it worked.
Great article.
Old 10/13/11, 9:01 PM
Roy D. Cooke, Sr's Avatar
Did not work for me earlier either ... Roy
Old 10/16/11, 9:40 AM
Robert J. OConnor's Avatar
That InspectApedia article primarily discusses older aluminum wire from the 1960's (called "old technology" wire) which was made differently than current AA-8000 series aluminum wire that doesn't need anti-oxident paste at connections ... http://en.wikipedia.org/wiki/Aluminum_wire
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 7:28 PM
Sub distribution panel 'over qualified' ? lfoster Electrical Inspections 7 4/12/09 7:56 AM
Electric Panel dmozzillo Electrical Inspections 26 1/26/09 1:18 PM
