Old 11/28/07, 9:39 PM
Steve A. Rinner Steve A. Rinner is offline
Question Ungrounded GFCI
Is an ungrounded GFCI outlet safe?
Bob Elliott's Avatar
Default Re: Ungrounded GFCI
Yes it does not need grounding
Old 11/28/07, 9:43 PM
So if I test with the 3 prong tester and it does not trip when the button is pushed and indicates an open ground, this is not a problem? Even w/in 6 feet of water?
Old 11/28/07, 9:44 PM
James H. Bushart's Avatar
This is a problem and is not connected to grounding.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Old 11/28/07, 9:47 PM
How is this reported?
Old 11/28/07, 9:49 PM
GFCI did not trip under test. Recommend that it be replaced by a qualified electrical contractor.
James H. Bushart
314-803-2167
Old 11/28/07, 9:55 PM
Steve did it trip with the test button?
If so then it is ok.
The test button I am refering to is the one on the recepticle itself.
Long as the wiring is not reversed it's ok.
This subject has been discussed many times so look at the nrew simular threads feature if itr is working and at the bottom of your screen.
Old 11/28/07, 10:05 PM
Robert, thanks for the info. My eyes are blurry from reading all the info on GFCI's.
I have one other Q. Is ther an issue if a light is conected to a GFCI outlet? IE: the light goes out when the GFCI is tested?
Old 11/28/07, 10:13 PM
Steve as far as I know it may just be a common sense issue as far as you will be in the dark everytime the damn thing trips.
Not good practice
Old 11/28/07, 10:19 PM
Unmoderated Guest
Robert's point is that a GFI will trip if tested with it's built-in test button, even if it is ungrounded.
It will not trip using a plug-in tester if it is ungrounded since those testers need a real ground for the test button to function.
An ungrounded GFI does not provide a ground. It provides a safer legal ungrounded receptacle.
Old 11/28/07, 10:27 PM
So, is an ungrounded GFCI outlet near the bathroom sink a safety hazard?
Old 11/28/07, 11:10 PM
Smile Re: Ungrounded GFCI
Steve it is perfectly fine as long as it tripped using the test button on the recepticle .
Speedy was reasserting what I said.
Check some of the old threads on this board.
GFCI will trip when it senses electricity not continuing it's normal path.
If electricity flows through your body it will kill the recepticle .
Regular grounding provides an alternate path for stray electricity.
GFCI with no ground is safer than ground with no GFCI.
Get it now.
Ok to anticipate your next question they do not have GFCI on everything because of cost.
Now do you get it. Good.
Old 11/29/07, 5:37 PM
William J. Decker's Avatar
An ungrounded GFCI (properly installed and working and trips from the built in test button) is providing GFCI protection. It is not providing grounding, which is an entirely different type of protection.
I would say, to your question, that any ungrounded receptacle in a house is a safety hazard (given current national electrical safety standards). I know that it may be OK, according to some local codes, but that was not your question.
Remember, local codes are only as good as those who write them and are a bare minimum requirement for the local municipality. It is perfectly possible for a house to meet the current local building codes, yet be unsafe.
Happens all the time around here. Ask the guy who got his neck broke when the pull down stairway (which was only secured with drywall screws, not nails) came loose. He will never walk again. This was new construction and the house had passed all code inspections. When asked, the local building dept said that the stairway was not required to be installed with nails and drywall screws were OK.
But it was not safe.
I always rely on current, national codes and manufacurer's installation instructions, rather than mere local codes.
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 11/29/07, 5:57 PM
Unmoderated Guest
Given than MOST items in a home only have a two-prong plug, can you elaborate as to why you think this?
Old 11/29/07, 6:02 PM
Michael Larson's Avatar
Great point Speedy. Will?
AFCI Questions and Answers - Mike Holt pabernathy Electrical Inspections 7 4/16/12 9:51 PM
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 7:28 PM
GFCI Safety Notice rcooke Electrical Inspections 1 10/30/07 12:29 PM
Ungrounded downstream GFCI scosta Electrical Inspections 17 3/9/07 8:00 AM
The question asked on the new HI Study test here? jtedesco1 Electrical Inspections 28 10/4/06 9:31 AM
