Old 5/29/07, 10:29 PM
gmaher gmaher is offline
Please Note: gmaher is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default ungrounded outlets!
I inspected a duplex on Friday that had grounded type of outlets throughout the building. Both living units were full of furniture since the inhabitants had not moved out yet. About one third of the electrical outlets were accessible for testing. EVERY outlet I tested in that duplex indicated NO GROUND CONNECTION. After I tested the third outlet in the inspection, I thought a trend had been established - no grounds! No grounding continued until I had tested all that were accessible; one third accessible), and I recorded it as such and told the realtor and prospective buyer. Then I got to the electrical service panel and found that there were not enough ground wires coming into the panel to ground all of the outlets in the unit!
The building was built in the early fifties and the interior walls were the same walls as in the fifties.
I told the realtor and prospective buyer that someone installed three prong grounding outlets into a two conductor wiring system with no ground wiring.
They asked why, and so did I. Then I mentioned it was to make the place look as though it had updated wiring when in fact, it did not.
Now the realtor calls me back and asks "how do I explain this to an electrician, cause he has to correct it before the sale will go through?"
I explained it to her again, several times, and finally she thinks she understands.
What else should I have done? How else could I explain it so she gets the concept? Isn't it a matter of deceit? Someone trying to fool someone else into a situation that isn't as it appears to be?
George Maher
Home - Safe Home, L.L.C.
Fargo, ND
Old 5/29/07, 10:57 PM
Doug Edwards's Avatar
Default Re: ungrounded outlets!
Sometimes it is not a sinister motive but purely economics or availability. The homeowner goes ditty bopping down to Wal-mart, finds the three pronged (grounded) receptacles are only 51 cents and the two prong are $2.50. Now he needs 30 receptacles, does the math and figures he can save $60 by just using the three prong. I see it here more often than not. Go back to the electrical archives as there are some detailed explanations on how to correct this IAW the NEC.
Old 5/29/07, 11:06 PM
cbrands's Avatar
cbrands cbrands is offline
Please Note: cbrands is a non-member guest and is in no way affiliated with InterNACHI or its members.
agreed.
although you can never rule out any sort of motive, this is usually done out of ignorance of the concepts behind their design.
many times, when explaining to clients that you just cant swap out outlets, they admit that they had no idea.
Old 5/30/07, 12:05 AM
They can simply install a GFCI for each circuit involved and then label the new outlets as having no ground, the labels are included with most GFCI's.
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 5/30/07, 7:10 AM
Ian Gills Ian Gills is offline
Please Note: Ian Gills is a non-member guest and is in no way affiliated with InterNACHI or its members.
I would be interested in knowing what wiring they have? I have a 1950s house with armored cable with the conductor strip along the casing. I used to have two prong sockets but installed three prong sockets since the casing and conductor strip act as a ground. Perhaps they have the same wiring and so thought that the receptacles would be grounded while forgetting to test for ground? Or pehaps they have the older BX wiring (without the strip) which cannot be used for this? It may be as simple as them forgetting to use self-grounding receptacles if they have Armored Cable and have metal wall boxes.
Old 5/30/07, 10:56 AM
jbreazeale jbreazeale is offline
Please Note: jbreazeale is a non-member guest and is in no way affiliated with InterNACHI or its members.
I don't think there's a sinister plot at work here, just pure convience and simple economics. Bruce makes the suggestion that I always make in such situations, concerning adding GFCI receptacles upstream on each circuit. It violates no protocols, adds a measure of protection against shock hazard to those old two wire systems, and is the least inexpensive alternative. That makes agents real happy. I might add that grounding is desirable wherever computer equipment is to be located
Old 5/30/07, 10:59 AM
MAN........how come my LapTop has no grounding plug on it's cord....maybe that is why my computer screens keep cracking...thehehehe
Paul W. Abernathy
Old 5/30/07, 12:17 PM
That was very flippant of you Paul.
I made reference to a "conductor strip" in AC and normally you pick me up on this. It is not a conductor strip but just a piece of metal to ensure the integrity of the outer coating. Unlike you to let this pass!
Old 5/30/07, 1:07 PM
This duplex has plastic covered cables coming into the electric service panels from all circuits, there are no wires coming in encased in metal conduit, solid or flexible. Yes, I believe the grounded outlets were probably installed just because they were cheaper, or the person doing it did not know exactly what he was doing, just enough to be dangerous.
Now I've got another "apartment" to do; a four-plex. Wonder what I'll find there!
Thanks guys.
George Maher
Fargo, ND
Old 5/30/07, 4:59 PM
lcapaul's Avatar
lcapaul lcapaul is offline
Please Note: lcapaul is a non-member guest and is in no way affiliated with InterNACHI or its members.
Maybe this will help
http://www.icgov.org/housing/documents/wiringalts.pdf
Old 6/1/07, 12:02 PM
Paul...wy u dis me, bro? u no dat be gud idee put dem grouns on dem puters!
De lawd gon' strike u down!
Old 6/2/07, 7:24 AM
it's all good fella......we all make mistakes..thehehe...but now you have to define "flippant" for me...I am from Virginina you know.
Paul W. Abernathy
Old 6/2/07, 7:26 AM
lol....man you know I love ya...even if your ground issue cracked my computer screen...lol
No actually...they called me yesterday....strangest thing...I sent the laptop for a crack in the screen...a SMALL one and they said they had to replace the screen which I knew they would...but they said the mother board did not pass inspection either....go figure.....so they replaced that also...now I am worried about this Toshiba.....yikes....
Paul W. Abernathy
Old 6/2/07, 11:27 PM
Paul, you da guru. We all know that!
Old 6/3/07, 12:15 AM
George -
Let me throw out a comment we might make in our reports that would explain the condition to an electrician.
"Ungrounded 3-prong electrical outlets were noted at many locations throughout the building. Have a competent and licensed electrician review the electrical system, the conditions and then repair or replace as needed to properly correct any electrical problems".
Properly Testing GFCI Outlets tchristopher Electrical Inspections 17 3/17/07 11:19 AM
Replacing 2-prong outlets with GFCI outlets kshepard Electrical Inspections 7 6/24/06 6:58 AM
Two prong outlets and GFCI's crichiii Electrical Inspections 8 3/15/06 10:41 PM
20 amp with 15 amp outlets abishop Electrical Inspections 32 1/31/06 4:21 PM
