Go Back   InterNACHI Message Board > Specific Inspection Topics > Electrical
Electrical Contains discussions about electrical systems. This includes outlets, panels, wiring, et cetera.
LinkBack Thread Tools Display Modes
Old 10/6/08, 6:11 PM
Andrew Cox Andrew Cox is offline
Andrew Cox is well trusted Andrew Cox is well trusted Andrew Cox is well trusted
Default Ungrounded outlets
I just inspected a house built in 1936. The electrical was recently (in 2001) upgraded to a 125-amp service, but there are problems.
First, I can't see where the box is grounded. I can see grounds coming in from the circuits, but no ground. Second, none of the outlets are grounded. They apparently rehabbed the house (a rental) about 10 years ago, and there are some 3-prong outlets, some are 2-prong. But none show a good ground with a tester.
Considering the age, how should I bring this up in the report?
Andy Cox
http://www.CoxInspections.com
Kissimmee, FL
You’re Your Own Job Security.
Old 10/6/08, 6:18 PM
James F. McKee's Avatar
James F. McKee has a reputation beyond repute James F. McKee has a reputation beyond repute James F. McKee has a reputation beyond repute James F. McKee has a reputation beyond repute James F. McKee has a reputation beyond repute James F. McKee has a reputation beyond repute James F. McKee has a reputation beyond repute James F. McKee has a reputation beyond repute James F. McKee has a reputation beyond repute James F. McKee has a reputation beyond repute James F. McKee has a reputation beyond repute
Default Re: Ungrounded outlets
Yes ...You should always mention ungrounded 3 opening outlets..the fact that they changed them makes them more of a problem than being un-grounded....looking at that configuration you could assume incorrectly a grounded circuit....they need to either add a ground....add gfci outlets or put back the proper two opening outlets...
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 10/6/08, 6:19 PM
Jeffrey R. Pope's Avatar
Jeffrey R. Pope .
Regardless of the age of the home, if you can't confirm a system ground, you should defer it to an electrician.
"We are unable identify the point where the system is grounded, which should be confirmed or established by a qualified electrician."
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
http://www.MyInspector.net
Old 10/6/08, 11:12 PM
Thanks for the advice. This place had a few more problems than just the outlets... a broken rafter tie, plus, when I got into the attic, the entire attic/roof structure was covered in black. They'd had a fire about 10 years ago. There was creosote everywhere...
Andy Cox
Kissimmee, FL
Display Modes
ungrounded outlets! gmaher Electrical 29 6/10/07 11:58 PM
Properly Testing GFCI Outlets tchristopher Electrical 17 3/17/07 12:19 PM
Replacing 2-prong outlets with GFCI outlets kshepard Electrical 7 6/24/06 7:58 AM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
