Home built in 1949. Addition in 2005 Original house section had 2 prong outlets and were changed to 3 prong but no ground as original wiring was not changed from 12/2 or 14/2. During addition renovation the elec panel was upgraded to 100amp and is done properly. there is house ground coming to the panel from that section of the house and all looks well there. Since the original part of the house was left alone is the ungrounded outlets an issue?
| Need a home inspection in Georgia? Check out InterNACHI's listing of Georgia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Grounding type receptacles are required to be grounded.
The receptacles should have been replaced with non-grounding type receptacles, or GFCI protected receptacles and labeled appropriately. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Thanks Jeff
What is the wiring method of these existing circuits? NM cable, AC cable?
| Ungrounded outlets | acox | Electrical Inspections | 3 | 10/6/08 10:12 PM |
| ungrounded outlets! | gmaher | Electrical Inspections | 29 | 6/10/07 10:58 PM |
| Properly Testing GFCI Outlets | tchristopher | Electrical Inspections | 17 | 3/17/07 11:19 AM |
