Old 5/17/11, 3:32 PM
John Gromkoski's Avatar
John Gromkoski John Gromkoski is online now
Default Upside down furnace switch
Inspected a home with a forced air heat/cool unit which had a service shut off switch installed "upside down" - ON in down position, Off in up position. The toggle switch itself had labeling which said ON and OFF respectively and was accurate. I found it confusing and called it out as a defect, as I wasn't sure whether power to the units was on or off. Wondering what others think about this.
774 Manor Road
Staten Island, NY 10314
718-514-3393
Need a home inspection in Missouri? Check out InterNACHI's listing of Missouri certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/17/11, 3:41 PM
Robert Meier's Avatar
Default Re: Upside down furnace switch
The NEC seems to agree with your assessment that it's a problem:
404.7 Indicating.
General-use and motor-circuit switches, circuit breakers, and molded case switches, where mounted in an enclosure as described in 404.3, shall clearly indicate whether they are in the open (off) or closed (on) position.
Where these switch or circuit breaker handles are operated vertically rather than rotationally or horizontally, the up position of the handle shall be the (on) position.
Old 5/17/11, 4:27 PM
Thanks Robert. I knew I could count on you to provide the back up!
774 Manor Road
718-514-3393
Need Date of Lennox Co Furnace (SR? 00 or 01 ?) Ja Florian Inspecting HVAC Systems 1 3/28/11 12:14 AM
Furnace Upside Down bpaull Inspecting HVAC Systems 3 6/11/09 11:18 AM
Emergency Shut-off switch sfalvey Inspecting HVAC Systems 4 8/18/06 9:11 AM
Furnace installed upside down mcotten Inspecting HVAC Systems 6 6/14/06 6:27 AM
