I inspected a house that was only two years old.
One three prong receptacle in every bedroom was upside down and one plug test open ground.....What would be the reason or was is it an installation mistake ? David PHI |
Yeah, when they're installed upside down, all the electrons run to the bottom. Thus, the reason for the open ground.
C'mon, Mark--I think David is serious.
There is no "upside-down" to a receptacle (and the electrons don't run out). The open ground was a mis-wire for a variety of reasons, but the installation was not a mistake--it's common to see them "inverted". "not just an inspection, but an education" www.homesweethomecincinnati.com Democracy is two wolves and a lamb. Liberty is a well-armed lamb. B. Franklin |
On my rehabs I have adjacent outlets in the same box installed in opposite direction - makes it easier to plug in multiple "wall-warts".
cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
If you have "one" in each room upside down it may designate the one that is switched. Some sparkies do it that way. And like Jay said----there isn't a "right" and "wrong" way----though some might argue otherwise
Thanks everbody so far....
David P-H-I |
Most of all upside down receptacles that I have found are on a switch that way you dont have search for it. Although most people dont know this.
Which way IS upside down?
<ducking for cover> |
rshuey is a non-member guest and is in no way affiliated with InterNACHI or its members.
was David serious?
lol |
Well, in case he was, there is no right or wrong direction to mount a receptacle. The reasoning for mounting them with the ground up is in case the plug were falling from its receptacle and something metal was dropped on the plug. Instead of the foreign object hitting a "hot" wire, it would instead make contact on the ground wire.
Russel,
Actually, on older 3-prong receptacles, there was a "top" indication. Originally the ground plug was to be installed above the hot and neutral openings. The ides, back in the day of metallic covers, was that if the mounting screw fell out (with a 3-prong line cord plugged in), the plate would hit the ground, instead of shorting across the hot and neutral. The designation disappeared years ago. |
| Outlets upside down in a 1969 build | rwashington | Electrical Inspections | 19 | 10/19/07 7:15 PM |
| Online Code Check- Reference | pabernathy | Electrical Inspections | 31 | 11/9/06 3:39 PM |
| Wiring a Receptacle | jallingham | Electrical Inspections | 9 | 8/6/06 4:34 PM |
| Furnace installed upside down | mcotten | Inspecting HVAC Systems | 6 | 6/14/06 6:27 AM |
