I have recently checked some houses in Elgin with a common builder and the under-sink receptacle for the dishwasher and disposal was a split duplex receptacle with a dedicated circuit for each appliance. This setup was protected by a 2 pole tied circuit breaker. When I questioned the electrical inspector he cited the 2008 NEC code for multiwire branch circuits, saying a common neutral wire required the 220v breaker.
It still seems to me that there would be a potential failure to trip if there was a problem on one appliance. Any comments? Mark Kollath Mark Kollath Home Inpection, Inc. Chicago |
| Need a home inspection in Alaska? Check out InterNACHI's listing of Alaska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
It's required. Under the 2008 it's required for all MWBC's, circuits with shared neutrals. In this instance it was required for many years prior to the 2008 code change since there are two circuits on the same yoke.
No comments. they work well and protects people who want to do electrical work by shutting of both circuits Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Circuit breakers are designed to trip internally. Even if the handle is held in the closed position the breaker will still trip. As Roy mentioned this was added to the 2008 NEC for the safety of someone working on the circuit with a shared neutral. Shared neutrals can be dangerous if they're opened with only one of the circuits turned off.
A wire, or some other "make-shift" tie may not pull the other breaker into the open position when there is a fault. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
If there was a fault situation in one of the circuits why would the other circuit need to open? Even a listed handle tie might not open the other breaker.
Edit... OK I just reread the thread, and think I got the answer to my own question. Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
There appears to have been no problems with this arrangement. Last edited by Brian A. MacNeish; 7/9/11 at 6:36 PM.. |
Someone posted a photo of a breaker a while back where Harry Homeowner had tried to "fix" a breaker that kept tripping by jamming a stick up against the breaker handle inside the panel ...
It didn't work of course because of the internal trip mechanism of the breaker. But ya have to give him credit for really trying to kill himself. Wish I could find that photo/topic again. It was priceless! Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
| Using 100 breakers on 220 circuits? | rsole | Electrical Inspections | 4 | 1/8/11 5:31 PM |
| 220 breakers on 120 circuits? | rsole | Electrical Inspections | 12 | 12/12/08 3:14 PM |
| What's this video worth? | jtedesco1 | Inspection Education & Training | 5 | 4/18/08 9:24 AM |
