Hey guys thanks in advance on this one. If a 120 volt well pump is wired to only half of a 240 volt breaker and nothing is attached to the other lug, its just empty, is this a acceptable practice. The reason that was given was that in the future a 240 volt pump can be installed. I let this go on a job, as I have done this myself in the past. Is there any hazard ?, does it overload the circuit to the pump? Will the breaker still work if there is a short? Thanks Ron
| Find an InterNACHI certified New Mexico Home Inspector (and anywhere else in North America) |
No problem. . .
Aren't breakers rated in AMPS?
Michael Merino Merino's Home Inspection & Education Inc. "Not just an Inspection, an Education"SM Phone/Fax 708~535~6057
Well yes, the protection rating of any general purpose breaker is in amps. I am assuming the question did not concern the ampacity rating of the breaker vs the load, but rather whether it is ok it use only one pole of a two pole breaker (which it is). Wasteful, but ok.
He should have said a "two-pole breaker" rather than a 240V breaker, but I think I understood the question. . .
I think your answer was clear.
Ahh, now I get it.
| AFCI Questions and Answers - Mike Holt | pabernathy | Electrical Inspections | 7 | 4/16/12 9:51 PM |
| Breaker Question | rsole | Electrical Inspections | 6 | 11/23/08 9:57 PM |
| Breaker Question | mhawley | Electrical Inspections | 5 | 1/14/08 3:25 PM |
| Electrical Guru Question? Breaker lock outs | pdoane | Electrical Inspections | 4 | 9/7/07 2:05 PM |
| Double Tapped Breaker | tjohnson3 | Electrical Inspections | 8 | 4/20/07 9:04 AM |
