Old 2/8/12, 8:33 PM
Scott Schultz Scott Schultz is offline
Please Note: Scott Schultz is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default verbage to write in the report
Saw a ground wire for the sprinkler timer wrapped around another ground wire that was properly attached to the buss. Since there were no more available screws, whoever installed the timer just wrapped the ground around the wire already in the buss. Hope this makes sense.
Thanks
Need a home inspection in Kansas? Check out InterNACHI's listing of Kansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/9/12, 8:01 AM
Unmoderated Guest
Default Re: verbage to write in the report
A wire nut or crimp connector should have been used. It may also be possible to pigtail the wires or add the second wire to the hole in the buss.
Old 2/9/12, 9:51 AM
Jeffrey R. Pope's Avatar
Keep it simple...
There is an improper grounding connection in the [service or distribution] panel, which should be corrected by a qualified electrician.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Regarding providing a copy of the report to agents and the seller.... gromicko Legislation, Licensing & Legal Issues for Inspectors 2 2/6/10 8:24 PM
Electrical Inzpections jtedesco1 Electrical Inspections 9 9/14/08 9:14 AM
New Washington Legislation Submitted gdomagala Legislation, Licensing & Legal Issues for Inspectors 294 2/10/08 1:20 AM
WA State Legislative update hmiller Legislation, Licensing & Legal Issues for Inspectors 153 5/4/07 11:55 PM
Texas Inspectors & March Texas REALTOR Focus Marc Tuno General Inspection Discussion 4 3/22/07 11:39 PM
