Old 6/7/08, 12:19 AM
Al D. Bolt Al D. Bolt is offline
Default Wadsworth panel
Any input on why Wadsworth breakers/panels should be noted? Are the older breakers known for failing to trip under normal overload conditions?
Thanks.
ID:	21792   wadsworth-panel-img_5648-small-.jpg.jpg
Old 6/7/08, 7:38 AM
Joshua L. Frederick Joshua L. Frederick is offline
Default Re: Wadsworth panel
I've always known Wadsworth to be a good quality breaker....also expensive... because they're good.
Old 6/7/08, 8:54 AM
Unmoderated Guest
One note. As of this year Wadsworth style breakers are no longer being made, by anyone.
Unless the molds and technology get bought up by someone they will eventually become obsolete.
Old 6/7/08, 1:37 PM
Pierre Belarge Pierre Belarge is offline
Please Note: Pierre Belarge is a non-member guest and is in no way affiliated with InterNACHI or its members.
It is somewhat hard to see, but it looks as though the Wadsworth panel is supplied from conductors ahead (Line side) of the meter.
Old 8/31/10, 10:09 AM
Jeffrey S. Campbell's Avatar
Jeffrey S. Campbell Jeffrey S. Campbell is offline
Send a message via AIM to jcampbell Send a message via MSN to jcampbell Send a message via Yahoo to jcampbell
For parts...supplies
http://www.aplussupply.com/break/wad/wad.htm
Jeff Campbell
Campbell Property Inspections
http://www.maineshomeinspector.com
Pittston, Maine
NACHI04013010
Old 8/31/10, 4:08 PM
Robert Meier's Avatar
It's hard to tell from the photo's but something doesn't appear right. Is this a service?
Old 8/31/10, 6:25 PM
Unmoderated Guest
Wouldn't sweat it too much Robert, this thread is over 2 years old.
Old 8/31/10, 6:44 PM
Thanks.
One of the reasons that, IMO, threads should be closed after 6 months.
Old 9/1/10, 10:30 PM
David Garton's Avatar
David Garton David Garton is offline
Originally Posted by Robert Meier View Post
Thanks.
We're still here
"If you work just for money, you'll never make it, but if you love what you're doing and you always put the customer first, success will be yours."
Ray Kroc
Old 6/3/13, 5:06 AM
dagel dagel is offline
I know not part of the original topic, and the thread is ancient, but wondering why nobody mentioned the signs of moisture entry/staining by the meter base
Old 6/3/13, 5:07 AM
And what is with the aluminum foil beside the meter base?
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 7:28 PM
Wadsworth Fuse Panel jhagarty Electrical Inspections 2 1/22/07 7:35 PM
Panel Inspection Safety roconnor Electrical Inspections 10 9/24/06 9:02 PM
