I inspected a home yesterday and found an old 100 AMP Wadsworth panel. It looks very unusual. I haven't inspected a panel like this before and I could not lift its front as it was painted over with several layers of paint. I couldn't open it without damaging the wall or fasteners. Does anyone have any experience with these panels?
Thanks! Pictures are attached. |
| Need a home inspection in California? Check out InterNACHI's listing of California certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Good panels, expensive breakers.
Maxim,
A very respected electrical contractor that I was on a consult with recommended that a Wadsworth panel be upgraded. He mentioned it in the same breath as an FP or Zinsco. Andrew MacDonald MacDonaldPropertyInspections.com InsightThermalDiagnostics.com ITC/FLIR Certified Building Science Thermographer ITC/FLIR Certified Level 1 Thermographer |
I would have to disagree with that assessment. Other than the age of the system, there are no inherent issues with Wadsworth systems.
ddelaney is a non-member guest and is in no way affiliated with InterNACHI or its members.
I'm with JP here. Wadsworth panels are a little hard to find breakers for in some areas, but they are very serviceable.
Thanks for advice guys! I explained to the client that the panel is ok but the breakers are hard to find. They are planning to replace the panel anyway when they buy the home.
| Electrical for Dummies | mcyr | Electrical Inspections | 16 | 6/9/08 9:59 PM |
