Warning signs that you need to fix the electrical wiring in your home!
[FONT=Calibri]Since identifying that you have an electrical wiring problem before it happens is next to impossible, as licensed electricians in Florida, we’d give you a few tips for early detection signs.[/FONT]
[FONT=Calibri]Once you notice any of these signs, call your electrician immediately and get your electrical system repaired or replaced.[/FONT]
[FONT=Calibri]1)When your circuit breaker trips frequently, it could mean that it is either overloaded or there is a problem with the wiring in your home. It may also be due to a faulty electrical appliance that is connected to the circuit.[/FONT]
[FONT=Calibri]2) If you notice that the lights in your house are dimming, especially after you’ve recently changed the light bulb, it might be an indicator that the wiring is faulty or that a circuit could be overloaded.[/FONT]
[FONT=Calibri]3)It is possible to start to smell a faint burnt plastic odor when wiring is damaged. Call an electrician immediately and get it checked out.[/FONT]
[FONT=Calibri]4) If there is flickering of the household lights it could be a sign that the electrical system in your house is outdated and overtaxed; however, it can also be a sign of damage to fixture wiring.[/FONT]
[FONT=Calibri]5) If any of the electrical outlets and switches in your house makes a slight humming noise, it could indicate an electrical problem with the device that was plugged into the outlet or there is the potential of loose wiring in the box.[/FONT]
[FONT=Calibri]6) If an electrical plate is hot to the touch, this is also a potential sign of an electrical wiring issue.[/FONT]
[FONT=Calibri]All these signs could indicate that there is a problem with your homes electrical wiring and a safety inspection by a licensed electrician should be completed immediately to help make your home safe.[/FONT]
[FONT=Calibri][FONT=Arial]www.delairelectrical.com
[/FONT][/FONT]
