Builder won't admit there is a problem with this house.
This was just one of many throughout this house. ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 9/30/08 at 7:37 PM.. |
Hmmm, I would have been curious and accessed this outlet.
Mike Whitt is a non-member guest and is in no way affiliated with InterNACHI or its members.
Could you explain what is happening a little more? |
Too long a cable run is what has been determined on these McMansions, in the past.
We'll see on this one. ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
Further info: http://www.idealindustries.com/media...64_165_ins.pdf ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 9/23/07 at 9:41 AM.. |
Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
Did the owners have something in their contract with the builder with respect to voltage drop? Lacking that, there's certainly nothing else that would bind the builder to "fix" anything.
Mark,
Is it true that they are addressing voltage drop in the 2008 NEC?? |
I see this all the time, in McMansions, and have been told by builders and even code inspectors that it is not a problem. I have never seen it fixed.
I have, in these same houses, had reports from the buyer (during the warranty inspection) that the big screen digital TV or the computer in the room died or had to be replaced, multiple times, on two cases. Digital deviced do not like voltage drops. I have seen some (pretty common, around here) as high at 25% at 12 amp load. It may be "code" (i.e., within local code), but it sure ain't right. Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
Not to bust your chops Will, but I used to test this type of power supply as an engineer to verify it was capable of outputing the corect DC voltage under the range of voltage input ratings on the label. The standard for this type of power supply is UL 60950. Output voltage — Linear power supplies regulate the output by using a higher voltage in the initial stages and then expending some of it as heat to produce a lower, regulated voltage. This voltage drop is necessary and cannot be eliminated by improving the design, even in theory. SMPSs can produce output voltages which are lower than the input voltage, higher than the input voltage and even negative to the input voltage, making them versatile and better suited for widely variable input voltages. Last edited by mlarson; 9/23/07 at 7:52 PM.. |
cgoyette is a non-member guest and is in no way affiliated with InterNACHI or its members.
Items with a transformer like all the new printers these days hate low voltage. The transformer gets real hot. The drop that is shown in the picture has the voltage down to 96 VAC that seems excessive to me and it was a WARRANTY inspection. I think the 5% rule is a bit overrated but way beyond that on this one.
Curt Last edited by cgoyette; 9/23/07 at 8:58 PM.. |
Curt Let me clarify the extenstion cord has a black box thats the transformer on the new printers and some copiers. |
You will have little to no voltage drop at low loads. The SureTest puts a 15 amp load on the circuit to measure that drop. At half that load, the voltage drop would be much, much less. At the load that a printer, for instance, puts on that circuit, the voltage drop wouldn't be anything to even talk about. The amount of voltage drop is directly proportional to the connected load. Here's a little chart that shows how much #12 you can run various distances for various loads if you're interested in maintaining 3% vd.: ![]() There is absolutely no way to know how a receptacle will be used in a home, so the application of a 15 amp load to calculate voltage drop is dubious at best. |
Marc, It took me a while to get someone in my area to understand that in a dwelling unit a load of 3 watts per square foot was all that was required to be installed. Their argument was the receptacle was rated at 15 amps so it should be loaded to 15 amps when doing a voltage drop test. I then ask if they knew what the required was to be used for a receptacle for commercial and industrial installations where the possibility of a large load to be connected was much higher. When he said no I point him toward 220.14(I) and told him this was the load used to size the conductors and overcurrent device for this same receptacle that he was loading to a full 15 amp load and pointing out a voltage drop. Quote:
Using this thinking a one and a half amp load at 120 volts would still have 110 volts on a 1000 foot run of #14. If voltage drop was a life safety issue it would be mandated by the building codes but it is nothing more than a design issue therefore not regulated by the building codes. |
| End of Warranty Inspections | poliner | Canadian Inspectors | 6 | 11/9/06 7:25 PM |
| Brink's Home Security offering our clients a free warranty on our inspections. | gromicko | Miscellaneous Discussion for Inspectors | 46 | 7/6/06 9:19 PM |
