Old 1/26/10, 11:17 PM
tdomingues tdomingues is offline
Default Washing Machine Outlet < 6' from Utility Sink
This is something I run into quite a bit. Today's inspection (new construction) has a duplex outlet (non-GFCI protected) for the washing machine about 3' from the utility sink. There is another GFCI outlet in the laundry room (not protecting above mentioned outlet). I would typically recommend changing the duplex outlet to a single to prevent someone from plugging anything else in. I am wondering what everyone else recommends. I have recommended GFCI outlets in the past and have gotten feedback from clients that the machine constantly trips the outlet. I am guessing this is caused by machines with heavier motor loads on startup. In those cases I recommended relocating and installing a normal outlet further than 6' from the sink. Comments?
Need a home inspection in Arkansas? Check out InterNACHI's listing of Arkansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/26/10, 11:36 PM
Bob Elliott's Avatar
Default Re: Washing Machine Outlet < 6' from Utility Sink
Tony , you do not want the Washing machine or dryer on an extension plug either.
Old 1/26/10, 11:40 PM
arook arook is offline
Please Note: arook is a non-member guest and is in no way affiliated with InterNACHI or its members.
There should be a non-GFI outlet for connecting the washing machine and dryer (assuming it's a gas dryer). If there's no gas dryer a single receptacle outlet should be used for the washing machine. All other outlets within reach of the sink should be GFI outlets.
Anything electrical with a motor (washing machine, refrigerator, microwave, etc.) can and do trip GFI's which is why they really shouldn't be plugged into a GFI.
Old 1/26/10, 11:41 PM
mnahrgang's Avatar
The plug is going to be closer than that to the washing machine connection anyway. Those hoses break often, yet the outlet has no requirement for GFCI there. So practically and logically, what is the difference? Besides as was stated earlier, it would nuisance trip all the time.
I personally would not call it out.
Mark Nahrgang
www.HeyMark.info
Old 1/27/10, 9:39 AM
Jim Port Jim Port is offline
Unmoderated Guest
Under the 05 NEC or later code the receptacle within 6' of a laundry tub requires GFI protection. No exemption for single receptacles. Article 210.8(A)(7) covers this. This should be called out depending on the code cycle. It could be recommended if not required.
Motors should not be tripping the GFI. If it does there is a problem with the appliance. I really wish this myth would go away about motors and GFIs.
Old 1/27/10, 9:53 AM
I did see the article 210.8(A)(7) in my 2008 NEC yet I see so many builders (as well as older homes) not putting them in the laundry room. Obviously, I would not recommend relocating outlets to the point of needing an extension cord. I will have to agree with Jim Port on this one and call it out especially on new construction since it is clear as day in the NEC. I know we aren't supposed to be necessarily calling out code; however, in safety related items such as this one I believe we should. I just don't get into the habit of putting the code article reference in the report which establishes a precedent which can later be used against me if omitted on a future report. Builder's hate me and this one was present during the inspection and tried to start an argument. I had to ignore him and continue with my inspection. My clients got a kick out of it. Thanks for the comments guys.
Old 1/27/10, 10:03 AM
iniquette's Avatar
iniquette iniquette is offline
Send a message via ICQ to iniquette
I agree with Jim. No exception for washers.
Got this from a HIP user I think. Might help.
http://www.your-leaking-house.com/si....0;attach=2305
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Active Rain Network
INACHI Awards Portal
Want To Exchange Links?
What we've got here is......failure......to communicate.....
Old 1/27/10, 10:41 AM
mnahrgang's Avatar
Ok, so NEC says it's wrong. But again I ask...
What's the difference between a sink and a hose that is known to burst?
Mark Nahrgang
www.HeyMark.info
Old 1/27/10, 11:03 AM
Unmoderated Guest
I won't get into a debate about the danger of a burst hose. My washer before this used the same hoses for over 15 years with no problems. I really don't see this as an issue.
With that said, the NEC specifies the GFI protection within 6' of the sink so it should be installed.
Just the fact that someone appears to be possibly trying to circumvent the code requirements really frosts me.
Old 1/27/10, 11:43 AM
David A. Andersen's Avatar
Please discuss "dedicated appliance circuits"...
BPI# 5015804
Old 1/27/10, 2:10 PM
Unmoderated Guest
What would you like to discuss about these?
A circuit dedicated for a specific appliance.
Old 1/27/10, 4:11 PM
William Warner's Avatar
William Warner William Warner is offline
I agree. I hear this myth repeated all the time.
Thanks Jim.
Visit the InterNACHI Awards web portal here
Blessed are the blissfully ignorant... for they shall be easily led...
Old 1/28/10, 12:07 AM
Paul W. Abernathy's Avatar
This is incorrect information.....If the receptacle for the washing machine is within 6' of the sink then under the 2008 NEC it would be required to be GFCI protected. Also motors are not going to trip a GFCI Device unless the motor is leaking current in excess of the listings of the product. I personally have my washing machine on a GFCI and it works fine....
Paul W. Abernathy,CMI,CPI,CME
Old 1/28/10, 12:17 AM
I stand corrected. Thanks for the update.
Old 1/28/10, 12:32 AM
I personally do not call them out if hard to get at, as in a double stack stuck in a closet.
Manufacture date of Maytag Washing Machine Unregistered AskNACHI.org Inspection Questions Forum 0 9/11/09 2:26 PM
Washing Machine Outlet lagudo Electrical Inspections 39 5/23/08 9:03 PM
Outlet under kitchen sink adooley Electrical Inspections 3 2/13/07 3:50 PM
Single lever washing machine valve phinsperger Plumbing Inspections 2 1/8/07 11:13 PM
