Old 9/13/09, 8:33 AM
Dean A. Conrad Dean A. Conrad is offline
Default Water in electrical panel
I inspected a garage under a home yesterday that contained the main electrical panel. When I opened it there was water standing in the bottom of the panel. Although the water was clear, a small amount of rust had accumulated on the surface, leaving the impression the water had been there for some time. The water was approximately a half-inch deep.
There are no water sources (pipes, etc) above the panel. The service line to the panel appears dry, and there are no stains present that would indicate where the water entered. Has anyone seen anything like this?
I doubt a dangereous prank was played because the home was vacant for some time and an old woman lived there when it was occupied.
Thanks,
Dean Conrad
Find an InterNACHI certified South Carolina Home Inspector (and anywhere else in North America)
Old 9/13/09, 9:30 AM
Unmoderated Guest
Default Re: Water in electrical panel
Did you look to see if the cable jacket was intact? Water can wick inside the jacket and into the panel.
Old 9/13/09, 11:10 AM
The cable jacket appears to be intact, also the top of the electric meter base and service entry with proper loop. Inside the panel, where the cable enters and the wires separate, there is no evidence of moisture or staining.
The buyers were present for the inspection and were equally amazed by this accumulation of water.
Dean Conrad
Old 9/13/09, 8:00 PM
Tim Spargo's Avatar
Just a thought...
Is this an area where condensation could have come in to play? Ext wall... condensation from above or in wall ...
A stretch I realize.
Tim Spargo
Spec Rite Inspections
661-317-5770
Old 9/13/09, 10:24 PM
Previous pressure-washing?
Frank P. Newman
Emerald City Inspections, LLC
Dublin, GA
Old 9/13/09, 11:59 PM
Mark Thorman Mark Thorman is offline
Unmoderated Guest
Please Note: Mark Thorman is a non-member guest and is in no way affiliated with InterNACHI or its members.
rodent pee pee?
www.MauiHomeInspections.com
Old 9/14/09, 4:15 AM
I think there was too much water present for it to be condensation. The presure washing is a possibility. This garage was located under the home and built in the 1920s. it is also one of the cleanest garages I've ever seen, regardless of age.
But I would be especially careful not to wet the electrical panel with water.
Thanks for the comments.
Dean Conrad
Old 9/14/09, 9:08 PM
Terry Clayton Terry Clayton is offline
I have often found the service entrance water tight SEU cable fitting on top of the meter will allow water to enter the meter and flow thru the meter and follow the cable into the panel. Its a wonder the meter don't blow off the wall from the water.
Old 9/14/09, 11:45 PM
wschreiber wschreiber is offline
I see this problem all the time.
Snow collects on the garage door. When the garage door is opened, the snow falls off the door and lands on the electrical panel.
The snow then melts and floods the panel with water.
Old 9/14/09, 11:56 PM
Bob Elliott's Avatar
I vote for followed the feeders.
See it all the time.
Old 9/15/09, 6:20 AM
Rick K. Kie's Avatar
Rick K. Kie Rick K. Kie is offline
I seen one yesturday were the meter was rusted through on the bottom left corner. There was also a bees nest in the panel.
Rick Kie
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 7:28 PM
Electrical Safety Foundation International Links jtedesco1 Electrical Inspections 5 12/8/07 3:10 PM
Access to Electrical Panel in Ontario by HVAC Contractors Nalliah Thayabharan Canadian Inspectors 10 5/21/07 3:01 PM
City electrical inspector says move the meter and panel cbottger Electrical Inspections 9 4/4/07 8:59 PM
