Have a 3500watt water heater on a 20 amp double pole, 12 awg.
If my math is correct 3500watt/220v = 15.90 amp. This shouldn't be an issue? "I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com |
Nope, pretty common actually.
Thing is, your calc is off a bit. "220" is dead. Unless you know for fact that the nominal voltage is 220v, we use a more accurate 240v. 120/240v is nominal these days. 3500w / 240v = 14.58 |
So Speedy, this setup should be ok?
Mike Whitt is a non-member guest and is in no way affiliated with InterNACHI or its members.
Also a fixed storage-type water heater that has a capacity of 120 gallons or less shall be considered a continuous load so that would be 14.58 times 125% or a load of 18 amps
Speedy
Should I also calculate the rating a 125%, which would be at 18.22 amps? "I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com |
Per the NEC
Yup, Mike gave all the pertinent info.
BTW these elements are rated at 240v, so if you really have 220v the watts will just be lower, by a factor of the square of the difference.
| Help. What is the correct way to report a breaker that is too big. | gromicko | Electrical Inspections | 77 | 5/10/12 6:13 PM |
