Vertical metal water line attached to building along side surface mounted electrical panel. Pipe goes to soffit, then turns away. Any requirements for water line distances from panel boxes?
Thanks. |
Water-line, gas-line, whatever - the metal piping is supposed to be bonded to the enclosure somewhere, so essentially, they're "touching" already. There is no separation required. . .
Unless of course the water line is within the equipments dedicated space or above it...otherwise it can be right next to it. Now, if that water line runs in a position that conflicts with the working space requirements around the equipment then possibly an issue...but for the bare basis of the question....not a problem.
Paul W. Abernathy |
Pierre Belarge is a non-member guest and is in no way affiliated with InterNACHI or its members.
Jeff That is probably the best explaination I have heard why it would/is permitted to install pipes close to the vicinity of panels. |
Thanks PB. . .
Thanks for your input.
| Leak in water line outside ... what is ... | Bill Featherstone | Plumbing Inspections | 6 | 1/12/08 8:17 PM |
| Reverse Osmosis | phinsperger | Plumbing Inspections | 3 | 10/30/07 6:28 PM |
| Solar water heating + electric water heater | Todd M. Soper | Plumbing Inspections | 20 | 5/30/07 6:31 AM |
| Water line repair program. | dmacy | Plumbing Inspections | 2 | 1/10/07 10:22 AM |
