Old 3/16/11, 8:37 PM
Darin Redding's Avatar
Darin Redding Darin Redding is offline
Default Water resistant covers for can lights in bathroom
The ceiling is 12', but no water resistant covers for the fixture directly above the shower. Would you write this up?
Darin Redding, CPI
Housecall Property Inspections
san diego home inspection
rental inspection | warranty inspection
Facebook Like
darin@sandiegohomeinspect.com
619-663-8740
home inspector in San Diego, Carlsbad, Poway, La Mesa, El Cajon, Chula Vista.
Need a home inspection in Kansas? Check out InterNACHI's listing of Kansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/16/11, 8:44 PM
Robert Meier's Avatar
Default Re: Water resistant covers for can lights in bathroom
Generally they're not required above 8'. They're not require below 8' if they are not subject to shower spray.
Old 3/16/11, 8:45 PM
Thanks!
Darin Redding, CPI
Facebook Like
619-663-8740
Old 3/16/11, 8:50 PM
Just to clarify, what type of fixture?
Old 3/16/11, 8:57 PM
recessed 6" can
Darin Redding, CPI
Facebook Like
619-663-8740
Old 3/16/11, 9:00 PM
Originally Posted by dredding View Post
recessed 6" can
OK, so at 12' nothing special is required.
Old 3/16/11, 9:01 PM
yea, that's what I was thinking from a risk perspective, but wanted to confirm the code. Oops, there's that word again.
Darin Redding, CPI
Facebook Like
619-663-8740
Old 3/17/11, 12:41 AM
Marc-Andre Beauchemin's Avatar
Marc-Andre Beauchemin Marc-Andre Beauchemin is offline
Why not have it go through a GFCI receptacle as to protect against murphy's law.
What if water does spray at the pot light and what if the cover does not seal well etc.
Beauchemin,Marc-Andre (CMI)
BMAinspection.com
Brossard-Quebec-Canada
Old 3/17/11, 12:45 AM
Jeffrey R. Pope's Avatar
Lighting outlets do not require GFCI protection.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 3/17/11, 12:53 AM
Marcel Gratton's Avatar
In the US that is...
On The Level Inspection
Gatineau, Québec
Old 3/17/11, 8:30 AM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
Default Re: No can lights in the bathroom on ceiling
It is still not a good idea to install a light in the shower. The difference in ambient temperature up above the can light may create moisture in cold weather. IR will show a high temperature and possible moisture migration above the can light. For this reason I always tell my clients to check above this area for moisture. They should install a high-powered vent assembly to remove moisture and should designed with a light on it installed just outside the shower. If this cannot be done I would recommend a light on the wall and not at the ceiling creating a penetration and pathway for moisture.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 3/17/11, 11:08 AM
True. Sometimes I forget to look up at you Norther folks
Jeff Pope
Santa Clarita CA
(661) 212-0738
no hot water in my upstairs bathroom drumell24 Plumbing Inspections 8 9/7/06 10:53 PM
Bathroom Shut-off Valves - Mineral deposits - Do you note them as leaking in reports? jwatts1 Plumbing Inspections 8 7/29/06 11:50 AM
