Hello, I did an inspection yesterday where all of the ground readings on receptacles were very weak. Should this be reviewed by an electrition? The dryer outlet was wired to a 1 pole 30 amp breaker. It should be wired to a 2 pole 30 amp breaker correct? Thanks for your help. Stan
| Find an InterNACHI certified South Dakota Home Inspector (and anywhere else in North America) |
1. I'm not sure what you mean by a "weak" ground system.
2. Most, if not all, electric clothes dryers require a properly-sized 2 pole breaker. Frank P. Newman Emerald City Inspections, LLC Dublin, GA |
Frank, Thanks for the quick reply. When using my sure test outlet tester the right side green light that shows a proper ground was very dim. I did take the outlet cover off of one outlet to take a look. Grounds were secured in the main panel. All conections were good. Stan
How close to the main panel is the dryer plug?
Got a pic of the single pole breaker? "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
Approx. 20'. No picture. Breaker is square D 30 amp single pole breaker.
The Sure-Test will give a flase ground if too close to the main panel because the neutral and grounds are connected there. 20' is too far away for this.
Are you sure the breaker is single pole, not single handle? If not, just report that it must be re-wired before use. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission Last edited by dandersen; 12/9/09 at 1:23 PM.. |
Dave, Thanks for the info. I am sure it is single pole. There are other issues too. Homeowner did the electric work. Thanks. Stan
The "weak-ground" indication is usually indicative of a worn receptacle. The grounding pin doesn't make sufficient contact, and that tester will show a dim light. The 61-165 will show a "open-ground" under the same condition.
Square D QO double pole breakers only have a single handle, not a double handle the width of the breaker like a Cutler-Hammer CH series.
| Hey Electricians... Can you help by proofing this new course? | gromicko | Electrical Inspections | 69 | 10/15/08 7:14 AM |
| What's this video worth? | jtedesco1 | Inspection Education & Training | 5 | 4/18/08 10:24 AM |
| Ground Wires Inside a Panel | mveitenhans | Electrical Inspections | 13 | 10/29/06 12:39 PM |
| Electrical Inspection Training for Home Inspectors | jtedesco1 | Inspection Education & Training | 6 | 4/27/06 11:43 PM |
